6.7 cylinder head problem - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 03-31-2013, 10:22 AM Thread Starter
In june 2012 i installed a new cylinder head built by mountain high performance, couple weeks ago the telltale symptoms of a blown hd gasket appeared so removed head & head has 2 hairline cracks between valves of cylinder #5, can the cracks be repaired or is a new head in my future? thanks for any advice
T-Albie is offline
post #2 of 23 (permalink) Old 03-31-2013, 04:47 PM
duallydaniel01's Avatar
any pics of the cracks? id suggest getting it pressure tested if theres someone near you that can do it. it just depends on where the cracks are at.
'08 RAM 3500 MEGA CAB SRW. II SILVER 64, II R1 NOZZLES, ARP HEAD STUDS, ATS STAGE 3 68RFE.
duallydaniel01 is offline
post #3 of 23 (permalink) Old 04-01-2013, 10:18 PM
6.7sledpuller's Avatar
Mine had about 20 cracks after this past season. I replaced my head with a used one. Don't know if you can see the crack from valve to valve in the pic
JL Builders 6.7 cummins sled puller Thanks to Motorsport Diesel and
ZEUS standalone too
DMP 2012 points champ
6.7sledpuller is offline
post #4 of 23 (permalink) Old 04-01-2013, 10:52 PM
ProStreet2wd's Avatar
New head. There are places that repair them, but I wouldnt trust them. If a seat comes loos, its ugly.
ProStreet2wd is offline
post #5 of 23 (permalink) Old 04-03-2013, 06:58 AM Thread Starter
thanks for the input, i talked to Bill at mountain high performance who built the head & he said the type of cracks in my head are very common & "normal " in almost all heavily modded 6.7's, he said the cracks like mine have to be a half inch deep before reach the water jacket, he said to have head pressure tested & that he's confident the head will test good & if not send him the head & they will fix the cracks, so i am having it pressure & go tested & will go from ther, the stock head i had before one im runningnow had over 12 visible cracks in all cylinders except one & tested no good of course but i have since added compound turbos & lowered my egts by over200 degs
T-Albie is offline
post #6 of 23 (permalink) Old 04-03-2013, 10:19 AM
07/67's Avatar
does anyone sell a ported and polished head?
2007.5 CC 4x4: Rough Country Long Arm Kit,Fabtech 4.5" progressive springs, 37"Discovery MT, MCC, Valair quiet dual disc,G 56 ,Dynatrac conversion, Airdog 165, ARP 625's, 4.56 , 467.7 SS manifold and a bunch of other sh!t!!!!
07/67 is offline
post #7 of 23 (permalink) Old 04-03-2013, 08:21 PM Thread Starter
ednumerous places offer a ported&polished head, but usually takes least 2-3 weeks if not longer to get one
T-Albie is offline
post #8 of 23 (permalink) Old 04-03-2013, 08:39 PM
07/67's Avatar
I have 156000 on my truck and I beat the hell out of everyday, I know I need studs but was thinking of replacing head, gaskets and installing studs. That way I know I'm safe. I will be upgrading the turbo and Arson III with 100hp injectors. If my head gasket holds out another 6 months I'll do everything at once.
Please recommend a shop that I can send my head to. Im in Louisiana if you know of any in my area.
07/67 is offline
post #9 of 23 (permalink) Old 04-03-2013, 10:08 PM Thread Starter
sorry, im in nebraska but maybe some one el closer to louisianna will recomend a reputable shop, this is my 2nd hd gasket with studs but first with head mountain high performance built for me, my cummins is a 08 4dr, ATS stage4 68rfe w5star torquecnvrtr& copilot,ATS compound turbo setup ( which i think is greatest thing since sliced bread) 125hp nozzles, airdog150, bunch of deletes,5in turbo back exhaust:,hiperformance head, autometer gauges, H&S minimax but goin to try EFI Live when get it back together
T-Albie is offline
post #10 of 23 (permalink) Old 04-03-2013, 10:35 PM
Bigger valves with some bowl blending will gain you more than a port job.
post #11 of 23 (permalink) Old 04-06-2013, 01:35 PM Thread Starter
prostreet2wd i agree, head i been running built by mountain high has oversized valves with bowls blended,, flow increase is substantial
T-Albie is offline
post #12 of 23 (permalink) Old 04-06-2013, 05:51 PM
Have you driven one with a big single? If you like the ats compounds, youd LOVE one with a big single.
