Can you hallow out dpf - Dodge Cummins Diesel Forum
post #1 of 41 (permalink) Old 01-04-2013, 09:30 PM Thread Starter
tmd3's Avatar
Can you hallow out the dpf and use a mini max
Sent from my SGH-T999 using Tapatalk 2
2007 6.7 slt with 6inch lift 22x11 35s afe intake custom grill headlights h&s mini max dpf delete work amp side steps afe diff covers train horn in progress
tmd3 is offline
post #2 of 41 (permalink) Old 01-04-2013, 09:46 PM
firemansdiesel's Avatar
Yes.........
Old: 1996, 2005, 2009, 2012 CTD - All Thuren/Carli Suspended and Goodies.
firemansdiesel is offline
post #3 of 41 (permalink) Old 01-04-2013, 09:47 PM Thread Starter
tmd3's Avatar
Will it work the same as a delete pipe
tmd3 is offline
post #4 of 41 (permalink) Old 01-04-2013, 09:55 PM
v10sport's Avatar
Yes stealth way of deleting
07 5.9L 2500 QC/LB 4x4. Edge J/A, Smarty TNT, AFE stage 2/ progaurd 7 filter Arson III 2G intake horn 6" lift 37 13.5 17 SS M-16 5"TBE Full Billet trans.
2012 3500 4x4 Auto DRW 4:10's Max tow. 5" TBE, EGR delete, CCV delete, Minii Maxx
v10sport is offline
post #5 of 41 (permalink) Old 01-04-2013, 09:56 PM
Punch out the Nox and DPF to make hallow. Re-install and use your Mini Max DPF delete tune. Looks and sounds stock.
post #6 of 41 (permalink) Old 01-04-2013, 09:59 PM
luke7474's Avatar
Sounds interesting if this bulll law passes ill put my stock stuff back on and do this
06 Mega/63over475/Fass/60over/Garmon Stg3/Intercooler/Firestone bags/Thuren lift/Trasher/Steed Speed/H11/110springs/DualCp3s/EFI/Coolant bypass/Pushrods/SOLD
2011 Black Dually Mega CAb Fully Loaded Fully deleted
luke7474 is offline
post #7 of 41 (permalink) Old 01-04-2013, 10:01 PM
EDGE82's Avatar
What law?
Sent from my DROID RAZR using AutoGuide.Com Free App
2002 dodge cummins 5.9, Red, 6" lift w/37's, 100hp injectors, stainless diesel 62mm turbo w/billet bullseye wheel, headstuds, valve springs, Banks High Ram Intake, royalty core grill, blacked out headlights w/8k HID'S.
EDGE82 is offline
post #8 of 41 (permalink) Old 01-04-2013, 10:08 PM Thread Starter
tmd3's Avatar
So will it still pass emissions
tmd3 is offline
post #9 of 41 (permalink) Old 01-04-2013, 10:49 PM Thread Starter
tmd3's Avatar
will it pass emissions if i hallow it out
tmd3 is offline
post #10 of 41 (permalink) Old 01-04-2013, 11:05 PM
Yes.... Visual it looks stock and if they do a opacity test. Then set the tuning software on stock deleted setting. Your only concern if your state plugs into your OBD port to check for readiness state of your emission sensors. Then you'll have to go back to stock because the tuning from H&S shuts off the EGR stuff among others. Will not show readiness and takes a few hundred miles to reset in stock configuration.
post #11 of 41 (permalink) Old 01-04-2013, 11:10 PM Thread Starter
tmd3's Avatar
ok i im do for my emissons so i went and took it in and the visual passed but my obd is not ready it says. i have the dpf delete pipe but i want to avoid this every year so i was thinking of hallowing out my dpf put it back on then put the mini maxx on stock and hope it works
tmd3 is offline
post #12 of 41 (permalink) Old 01-04-2013, 11:14 PM
Expensive gamble. Once gutted, your stuck buying a new one if you need it. A delete pipe is a lot cheaper and easy to swap in and out.
cosmok is offline
