another post on which turbo... - Dodge Cummins Diesel Forum
Old 07-13-2012, 03:54 AM   #1 (permalink)
railin 6.7's Avatar
ok, this part of the long story, short.
got into truck cold, went hard on the hammer, did some of this and some of that... bye bye HG.
resurfaced head, dropped springs, studs, gasket and a waste gate on her.
replacing turbo/manifold here by august once i get more info and do more research into this, as im new. theres a lot of info on here, but threads seem to get off track fast.
im not looking for crazy numbers, maybe one day be in the 6's (hp, not the 1/4), but im wanting to do so with less smoke than what im seeing around. how might this be possible? seems ill be needing more fuel to get into that range, but with more air, should cut the smoke back? what are ppl running turbo wise with stock to little fuel that is keeping relative spool? what helps with spool...this pressure that pressure... help anyone?
also ppl with DP issues... after swapping turbos etc etc, has any one hooked up a dp gauge and seen the differences?
thank you for looking into and any info
'07.5 - 6.7l, g56 3250SB, cold air, intercooler w/boost tube, 4'' tbe, xrt, maxx flow intake w/ boost tube and gdp ghd, fass 150, new head gasket, studs, springs, waste gate to begin...
railin 6.7 is offline   Reply With Quote
Old 07-13-2012, 06:36 AM   #2 (permalink)
goblue's Avatar
To keep close to stock fueling i would go with a 3rd gen set up which consists of a aftermarket manifold and turbo. From what research i have done a silver bullet 66 seems to be about the size of turbo they should of sent stock for these trucks. It safe to say that 600 is achievable with the right tuning. I would recommend Efi live as a tuning options as it will just flat out make your truck run better. Ryan from suncoast Dave Mathews are great just to name a couple. Or purchase MCC and see what someone can do with that. There is so many viable options anymore its crazy. As far as dp after giving these trucks the correct sized turbo for the displacement it will be certain to see a drop in dp especially if your keeping stock fueling.
08 6.7, 2Gen steedspeed,467/83/91,50% over gdp nozzles,Air dog 165II,floor it stage 3 bop,h&s horn,5" ss,4" h&s boost tube, bd intercooler, cts, hamilton springs & rods, arp,EFI Live, gdp ghd.Revmax comp 68rfe
goblue is offline   Reply With Quote
Old 07-13-2012, 06:42 AM   #3 (permalink)
1998dsmtalon's Avatar
Id think a 66 on stock fuel would be laggy.
Sent from your moms house
06 QCSB 1 pump 1 turbo 756 hp/1256 tq
Wilson Diesel Performance
Tuned by Innovative Diesel
1998dsmtalon is offline   Reply With Quote
Old 07-13-2012, 06:48 AM   #4 (permalink)
goblue's Avatar
Not on a 6.7 and not with the right tuning if this give you any idea im running a 467/83/91 100 hp stick and efi live tuning and its darn close to stock spool. Elevation makes a difference to but even that can be mitigated by tuning and a little more fuel ie lift pump nozzles.
Old 07-13-2012, 09:29 AM   #5 (permalink)
spyder90's Avatar
iTrader Score: 10 reviews
I just installed a SB 66 with a DPS 3rd gen manifold and ARP studs about 3000 miles ago and I love it. No lag at all and it helped clear up some smoke. I am only running a mini maxx, everything else fuel wise is stock. I have yet to hook up a DP gauge but the truck runs a lot better and cooler with this turbo and the install was simple.
2002 2500 Single Cab
spyder90 is offline   Reply With Quote
Old 07-13-2012, 10:00 AM   #6 (permalink)
Farmerbrown's Avatar
There always has to be one 5.9 guy who thinks it will be laggy. You have to remember there is a lot more air moving on a 6.7.
2008 Dodge 2500 Mega cab Laramie, Ats 68rfe with copilot
Farmerbrown is offline   Reply With Quote
The Following User Says Thank You to Farmerbrown For This Useful Post:
WouldRatherbeCummin (07-15-2012)
Old 07-13-2012, 10:09 AM   #7 (permalink)
Temple Diesel's Avatar
iTrader Score: 15 reviews
I will be going with a S366/73/.91 T4 on a 3rd gen PDI manifold with Arson IV and stock injectors. Last but not least EFI Live by Dave Matthews
2008 "Smurf" | ARP 625's | EFI & H&S OD Tuning | GUCCI Suspension
History
2006 Cummins Mega White/Black
2006 Cummins QC Red/Black July issue of Diesel World 11'
2002 Cummins Grey/Black best of 636/1198
Temple Diesel is online now   Reply With Quote
Old 07-13-2012, 10:10 AM   #8 (permalink)
goblue's Avatar
Old 07-13-2012, 12:52 PM   #9 (permalink)
railin 6.7's Avatar
GOBLUE: you running 50% over injectors? hows it do on smoke, though i see ur tuning with efilive...
ill probably be sticking with my xrt for tuning unless its somehow more smokey, but it shouldnt bei take it with only adding more air, right? im a tad lost with size arrangements. i see them written as 66/71/14 and then theres 66/71/.91... inlet, impeller, ??. bigger the .XX the more air on exhaust side? im pretty new into this so bare with me a little please.
**heres where the thread will go off track. lol.
what are ppls thoughts on the arson kits? its basically allowing more fuel into and from the cp3? whats that doing to the stock injectors and how much harder with that be on them?
truck is dd that pulls 10k give or take a few k, 3x a week anywhere from 20-200 mile round trips... lots of hills, lots of 4wd.
ill be running lovefabs manifold. so that info im good on
Old 07-13-2012, 12:59 PM   #10 (permalink)
ATS Diesel Performance
RAN '07@ATSDiesel's Avatar
Stock fueled 6.7 with Silver Bullet 3rd gen setup.The only fuel mod was a airdog 150.
07.5 mcsb, Crower rods, Stage 4 68rfe, B&B side mount intake, ported head, II 120% CP3, Exergy injectors..........turbo too be decided soon
ATSDiesel 866-209-3695 ext. 160
Aron@ATS Diesel.com
http://www.atsdiesel.com/images/cumminsforum/aron.png
http://ats.tw/cfaron
Sponsored by:Blacks Diesel Performance, Rollin Smoke Diesel, All American Diesel Performance, Draconian Diesel, and Isspro
RAN '07@ATSDiesel is offline   Reply With Quote
The Following User Says Thank You to RAN '07@ATSDiesel For This Useful Post:
railin 6.7 (07-13-2012)
Old 07-13-2012, 01:10 PM   #11 (permalink)
railin 6.7's Avatar
i like it RAN. i like the next video that came up after, of the 659hp with the 66. also looks like its a 5.9 though.
RAN,youve gone through a few different setups havent you now?
Old 07-13-2012, 01:14 PM   #12 (permalink)
goblue's Avatar
Oh where to start , i tow a 15000lbs 5 th wheel and i have plenty of power 50% over are the injectors. I have a little puff of smoke if i mash it from a dead stop the turbo almost instantly cleans it up but keep in mind im at sea level and i have a larger housing turboo s400 class. I can imagine there higher elevations as to where you live and in my opinion if your wanting to stay with stock fueling and dont want the lag i would stay with a s300 housing turbo. With efi live they can write custom tunes for your truck tell them what your doing and what you want and they can do it for you up to mechanical limitations. As for thr cp3 upgrades someone may be able to chime in on brands but i believe a stock cp3 is good foor 550-600 hp.
The Following 2 Users Say Thank You to goblue For This Useful Post:
commtrd (07-14-2012), railin 6.7 (07-13-2012)
