Exhaust Drone Fix - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 04-25-2012, 02:51 PM Thread Starter
Exhaust Drone Fix
After installing my new Flo Pro 5", turbo back exhaust, I ended up with the loudest drone you can imagine. Drone is different than exhaust sound. I love the sound of my 5" exhaust, but the drone drives everyone in the cab nuts. After talking to Flo Pro techies, I ordered their Twister Resonator. I installed as instructed, onto the down pipe and left the straight through muffler installed.
Result--absolutely no drone--none--nada--zip. We can talk normal in the cab again without feeling you are inside a bellows.
RAM 2012; 3500. All stock for now. The real Cummins engine is in there. You just have to dig it out!
Bill_C is offline
post #2 of 25 (permalink) Old 04-25-2012, 04:58 PM
jwhjr1971's Avatar
I wish I would have known that. I scrapped the muffler and installed a Donaldson to get rid of the drone.
2012 3500 SRW 4x4 Laramie Longhorn Mega Cab / Automatic / Smarty Jr ME / Shibby Engineering EGR, EGR Cooler, and Grid Heater Deletes / Flo-Pro 5" TBE / AMP Research Steps / Weather Tech Vent Visors / Weatherguard Tool Box
jwhjr1971 is offline
post #3 of 25 (permalink) Old 04-25-2012, 06:00 PM
Mega10Cab's Avatar
Mine drones real bad at 1100 rpms and 2200rpms, but I also have a straight pipe. eventually I'll get a resonator but for now I enjoy hearing my exhaust finally.
If you dont mind me asking, how much did the resonator run you?
2010 2500 4x4 Big Horn, Smarty, MP8, Deleted, 5" Flo Pro, GDP Open Breather, Silencer Ring MIA, leveled, bilstein, Timbrens, 20s/33s, Carli Low-mount, Tint, Laramie Flares.
Mega10Cab is offline
post #4 of 25 (permalink) Old 04-25-2012, 09:17 PM
5" MBRP SS turbo back with there muffler you see the twisted dimples on the inside of the muffler there is no drone to this system.
RSRains is offline
post #5 of 25 (permalink) Old 04-25-2012, 11:50 PM Thread Starter
$70.00, plus shipping.
Bill_C is offline
post #6 of 25 (permalink) Old 04-26-2012, 03:17 AM
wixthedog's Avatar
Was your part number 51600? I assume a 51299 would be for the 4" set up? I hate the drone but I love the exhaust note. The higher RPM's from the G56 make it worse since it hits from 2000-2200 or so.
Have a pic of the install?
2016 2500 CC 4x4 6.7 68RFE 3.42 - Silver
'15 Crew Crab 1500 = '14 Mega 2500 = '14 Crew Cab 3500 = '13 Crew Cab 3500 = '07 Quad Cab 2500 = '03 Quad Cab 1500
wixthedog is offline
post #7 of 25 (permalink) Old 04-26-2012, 09:11 AM Thread Starter
Part number is Flo Pro Twister 51600. I didn't take any pics as the install was so easy and fast. The outside diameter of the resonator is 5", same as the exhaust system. I removed the exhaust system from the down pipe to the muffler. Then using the resonator as a measuring tool I marked the intermediate pipe (make sure you don't cut off the muffler end of the pipe), you need to shorten that pipe to fit in the resonator. I marked the full length of the resonator then added 3.25" that you need to slip into the outlet of the resonator(to make that clearer, measure the length of the resonator, subtract 3.25" and you have the length of pipe to cut off). The resonator fits exactly as the system was before. It is recommended to fit the resonator to the down pipe. I'm happy, dogs are happy, wife is super happy.
Bill_C is offline
post #8 of 25 (permalink) Old 04-26-2012, 09:19 AM
iTrader Score: 17 reviews
if it makes you feel any better, your exhaust has less backpressure :p
drunk on diesel is offline
post #9 of 25 (permalink) Old 04-26-2012, 10:12 AM Thread Starter
I don't know how much back pressure is added with the Twister resonator. I would think it to be very small. When you look into the resonator the centre is a 1" or 1.5" straight thru pipe, didn't measure it. This centre pipe is held in place with a double spiral tunnel( I think close to a double spin, front to back), this is probably where they get the name Twister. As I understand it, the drone comes from the exhaust pulses leaving the turbo. If you like, compare it to a person blowing smoke rings. The exhaust comes out in 'puffs'. With the original exhaust system these pulses first hit the cat converter, then the nox thing, then it enters the DPF, then it enters the muffler and finally out the tail pipe. At this point the pulses are all blended together, giving a smooth exhaust outlet. Getting rid of all this junk allows the pulse to travel from the turbo right out the tail pipe. The Twister puts a spin into the exhaust gas, blends the pulses and gets rid of the drone.
This is as I understand it. Makes sense to me.
Bill_C is offline
post #10 of 25 (permalink) Old 04-26-2012, 11:24 AM
I didn't say it was a lot, but it does induce some vs. straight pipe or that donaldson
post #11 of 25 (permalink) Old 04-26-2012, 11:31 AM Thread Starter
I Agree, 100% over the straight pipe, I don't know anything about the Donaldson.
Bill_C is offline
post #12 of 25 (permalink) Old 04-26-2012, 02:43 PM
2000 rpm is our drone sweet spot. I have the cat in place in the downpipe, the bulges are hollow and the muffler is in place.
2007 2500 Mega 6.7L EFI Live, ATS Stage 2 68RFE w/ CoPilot, MHP/B&G TCM Mod Tune, 2 WD w/ NV271 Manual Transfer Case, Edge JWA Gauges, Nitto Terra Grappler 285 70 17, Fixed the DPF, NOX and EGR, much better now, AFE Stage 2 Pro Dry, Shibby Stage one intake, BM EWG, Autometer 7504/7505/7506 Boost gauges, Maxxbrake controller, Rancho 9000XL with MyRide, Hellwig air bags, A wealth of stealth.
2500MegaDiesel is offline
