well here is a list of the codes I have after deleting the DPF, as of now it's still running fine with a CEL on, but the overhead still reads "system ok" I don't know how many miles i've put on it so far, but it's not derated the engine or went into limp mode yet, what are the chances of that happening with these codes ??
P2032-exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 2
P242c-exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 3
P0545-exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P200c-diesel Particulate Filter Over Temperature - Bank 1
P200e-catalyst System Over Temperature - Bank 1
P244d-exhaust Temperature Too High For Particulate Filter Regeneration Bank 1
P242b-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 3 -diesel
P1484-catalyst Overheat Detection
P2453-diesel Particulate Filter Pressure Sensor A Circuit Performance
don't know exactly how on Poindexter6144's truck he only showed 2 codes???? cuz I'm def. seein 9 on mine!! LOL Dusty
07' Classic 3500 Dirtymax crew cab dually LT DVD black on black on black, paint interior and rockstars! PPE standard, 5" exhaust, egr blocked,transgo jr. autometers, smoked cablights, rhino-lined, 235/85-16 m/t's, front and rear flaps, tow mirrors, billet grill
straight pipe with no sensors at all, I unplugged the sensors & then put a jumper wire in the end to cross the wires in the plug in itsself, haven't messed with any resistors or anything yet, waitin on BADP to get a fooler box finished for it, Dusty
yeah, but I did the same thing as he did when he first tried it & then I end up with 9 codes & his is only showing 2? unless his scan tool just isn't showing them all??? I finally got my truck to show the codes by turning the key on/off 3 times, I had to do it really fast like within a couple seconds & it worked?? Dusty
Clear them and see if they what ones come back.
2007 5.9 2500 4x4, BD Race twins, industrial Inj Twin CP3's, Industrial Inj Stage 2 Injectors, Smarty TNT-R stacked with Quad X2 CFM+ Built Tranny by Jason @ Diesel Nut FASS
2007.5 6.7 2500 4X4, Juice with Attitude, DPF delete and EGR Delete AFE stage 2 MP8
how do I clear them??? w/out the Edge or power pup? I just checked mine by turning the key on & off?????
three start stop cycles might clear them, if not drive it around town and start/stop the truck a few times. After the third start up they should be gone if they are going to go away.
2006 Mega Cab 3500 SRW : EFI Live tuned by Relentless Diesel: AFE Stage II intake : 5" Flo Pro Exhaust : Suncoast valve body : Billet input shaft : Suncoast triple disc converter : Billet front band : Billet servos
well they're still there, except now there's 11 of them!!! dunno what the other 2 are cuz I was just countin as it went through them, but I'm starting to think that I may end up in limp mode with all these codes??? that would be no good!!! LOL
Yikes! 11 codes sounds like trouble if you don't get a handle on it quick. Do you have a device to clear the codes without going to the dealer? Are they all too do with your exhaust mods?
2008 3500 QC BBQ Build in progress
2012 3500 CC Build also in progress
You have a wire in each of the 3 plugs jumpin them across? Id check and make sure there in there good. I dont see why it would work on mine with only 2 codes and not on yours and throw 11 codes Youd think they would be the same
2007 quadcab 4x4/ C&C/ DRW / bradford flatbed /6.7l/6spd auto/4.10/EGR system Dpf and muffler are collecting dust in the barn,SMARTY
kinda what I'm thinking & I'm still waiting on a friend's power pup to clear these dang things? just driving it & the key cycles isn't clearing them at all?? gonna go back & read poindexter6144's post & make sure I jumped everything right, but it seems like it wouldn't read "system ok" on the overhead if it detected a problem bad enough to derate the engine????? dunno guess we'll see???? LOL
