I put my DPF and EGR back on to sell the truck. The truck ran rough after the reinstall, so I checked everything and found I did not have the intake butterfly valve plugged in. I hooked it back up, then the truck went into limp mode. Shows PO489 code, "EGR control circuit low". Is there something else I am missing for the reinstall?
Will I have to have the dealer take it out of limp mode?
Had the Smarty S-67 tuner when deleted, and put everything back to stock on the tuner after the deletes.
08 2500 Quad Cab 4x4 Bighorn package, missing DPF and EGR, Smarty. Carli Starter kit, KMC XD Spy 797 20x8.5" +18 offset Nitto Terra Grappler 295/60 E Rated.
Did you put the plunger and all those goodies back in too?
If you flashed it back to stock WITH the throttle valve not plugged in, you'll need to flash stock again, now that it IS plugged back in, then clear codes twice and try again.
2001 QCLB 3500 Dually 4X4, Stock, FOR SALE 8000 OBO
2003 QCLB 2500 640 HP / 1125 ft/lbs SOLD!
Parts for sale Van Aken SmartBox, Stage II Monster Pump, DPS 62/75 Twins, and FASS 95, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. Parting out 08 3500. http://www.cumminsforum.com/forum/07...-part-out.html.
The Following User Says Thank You to Shibbyutman For This Useful Post:
Try clearing the codes and see if that does it.. you may have to clear them 2 or 3 times even after the first clear it will say there are no codes but go ahead and clear it again.
2007.5 4x4 big horn,lifted,Gunner 8 wheels,35 12.50 20 nitto mud grapplers,425 studs,Air boss gird delete,EGR/cooler delete,DPF NOX delete, Diamond eye exhaust, Airaide intake , Smarty Sr 25me, H&S tuned TCM, B&D manifold and 64/71/14 turbo, Edge Insight
Thanks, I'll give that a try.
Anybody by you have an XRT? For one reason or another those clear more conditions while flashing..
