E.D. 2nd Gen w/PICS - Dodge Cummins Diesel Forum
Old 10-22-2011, 10:24 AM   #1 (permalink)
TheMike's Avatar
E.D. 2nd Gen w/PICS
Alright, so I got everything cleared up here with the install. Had a small boost leak but Chris at E.D. got me fixed up with some overnight parts. Now for impressions:
It drives pretty well. Spool-up is not quite like stock and is a tad laggy. I don't drive with my foot in it all the time so maybe that is where I fail compared to everyone else that says this size turbo spools like lightning. Let me say to those of you who are planning to do a 66/74 or bigger you must keep your foot in it and turn your tuner up. I personally don't like driving like I stole it everywhere I go. The max boost I hit with MM on HOT was 35psi at 80% throttle. Normal, "real", daily driving it makes about 10-15 psi with tuner set to MIld and throttle no more than 35%.
2008 6.7L Mega
*REVMAX Signature 850 68RFE - Stg 5 TC | H&S Minimaxx | Fleece ManTake | Stainless Diesel Manifold | Billet S366/74/.91 (T4) | Motorsport Arson III | 100hp nozzles | FASS 150 | Glacier Diesel S-3 & 3.5" Boost Tube | ATS H-11s | Thuren Fabrication | Retro Shop Projectors w/6000K HIDs | Fuel Throttle 18x9s | Toyo A/T II 285/75/18 | AMSOIL
TheMike is online now   Reply With Quote
The Following User Says Thank You to TheMike For This Useful Post:
Rockwerx (10-22-2011)
Old 10-22-2011, 11:04 AM   #2 (permalink)
You need to get some insulation near you wire loom. You WILL burn a whole in it! Any particular reason you went flipped instead of dropped?
blackmega3500 is offline   Reply With Quote
Old 10-22-2011, 12:07 PM   #3 (permalink)
TheMike's Avatar
Where do i get the insulation? That's the way the ED kit is designed. It's supposed to make it easier to swap turbo later.
2008 6.7L Mega
Old 10-22-2011, 12:55 PM   #4 (permalink)
WouldRatherbeCummin's Avatar
nice looking install!! which housing did you get the 14 or 16? i find it hard to believe its laggy my buddys truck with the same
mods as yours spools like stock to me
2012 Mega cab 2500 4x4 LIMITED
4" pure performance, carli oposing stabilizer, Retro-soultions HIDs, ridin' 22x10 fuel nutz with 35" trail grapplersH&S minimaxx, 5" TBE, egr delete, FASS 150 with Alligator sump... more on the way!
WouldRatherbeCummin is offline   Reply With Quote
Old 10-22-2011, 01:16 PM   #5 (permalink)
Iced2's Avatar
Nice write up. I was wondering the same thing about spool time and how it was under normal driving. So with all the time and money are you glad you went with the swap? Do you see gains in MPG's or what are pro's have you seen so far.
2007.5 Dodge Ram Mega Cab 2500, EFI Live running MGP tune from Dan's Performance Diesel "Smarty's all gone" DPF , EGR,EGR cooler deleted. Grid heater delete & GDP stage 3 Intake
Iced2 is offline   Reply With Quote
Old 10-22-2011, 01:38 PM   #6 (permalink)
Id recommend a turbo blanket which will retain the heat in the turbine housing and help you spool the charger all for $99 from Levi @ turbo performance products.
The Following User Says Thank You to blackmega3500 For This Useful Post:
TheMike (10-22-2011)
Old 10-22-2011, 01:48 PM   #7 (permalink)
TheMike's Avatar
It's a 0.91 A/R which equates to about a 16cm housing if I'm not mistaken. It's T4 flange. I didn't think it would be laggy either from what everyone else on here said, but I was suprised to find out how much better the stocker is at spool up.
2008 6.7L Mega
Old 10-22-2011, 01:58 PM   #8 (permalink)
TheMike's Avatar
In hind sight I probably would not do it again or I should've got a different turbo/install kit. Should've saved my coin and just got a GDP wastegate and left the stocker on there. I want to hit 550-600 hp and have a solid DD truck that spools quick. As far as MPG, I really don't have any miles on it to tell. Pro's & con's.....well
Pro's:
- plenty of room to grow, if you're not shooting for 800hp
- low EGTs
- ease of later swap, add twins
Con's:
- laggy unless you run tuner to kill or add nozzles
- very loud in cab, exhaust drones now even w/Flopro muffler
- pricey
- lost some low end torque and punch
2008 6.7L Mega
Old 10-22-2011, 02:17 PM   #9 (permalink)
Iced2's Avatar
Pro's:
- low EGTs
Con's:
- pricey
Ya i was looking at just getting a waste gate to but when i started reading that swaping turbos would net higher MPG's i started looking into it. I was also looking into the Wildcat VGT's but with no one running it its hard to pull the trigger on that... Keep us updated with the MPG's really intrested in that.
Old 10-22-2011, 02:24 PM   #10 (permalink)
seanth468's Avatar
iTrader Score: 5 reviews
All you need to do now is paint the plate on the t-stat housing JK. looks like a clean install
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Smarty,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Hankook 285 ATM RF10's.
seanth468 is offline   Reply With Quote
The Following User Says Thank You to seanth468 For This Useful Post:
Old 10-22-2011, 02:43 PM   #11 (permalink)
that may have a little to do with your spool
Old 10-22-2011, 02:46 PM   #12 (permalink)
TheMike's Avatar
I ordered a black turbo blanket from him. I got the one for S300/400 non-gated housings. That's the one right?
2008 6.7L Mega
