We put some rubber sheets inbetween the frame and the Airdog mounts to help isolate any motor vibrations from the pump. Just before you tighten up the clamps, lift the unit up so that the top bolts do not rest on the frame. My unit is quieter than many of the same units that did not use some rubber shims. It is easy to do and may help with your problem.
2008 3500 QC BBQ Build in progress
2012 3500 CC Build also in progress
The Following User Says Thank You to Rockwerx For This Useful Post:
you can take the gear pump cover off with those few allen head screws on the end and try cleaning in there to inspect for debris. I know lately AD has had some problems with motor shaft hardness and diesel fuel ingress into the motor.
2001 QCLB 3500 Dually 4X4, Stock, FOR SALE 8000 OBO
2003 QCLB 2500 640 HP / 1125 ft/lbs SOLD!
Parts for sale Van Aken SmartBox, Stage II Monster Pump, and FASS 95, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. Parting out 08 3500. http://www.cumminsforum.com/forum/07...-part-out.html.
yea it will squeal for a second then just stop. Let me ask you something, how do you like the edge and smarty stacked on your truck?
I uze the edge mostly for the gauges. I do plan running Smarty on "stock" and running the edge on "HOT" once again just to compare. I had the Edge on "HOT' before getting the Smarty but have not gone backwards for a comparison.
08 srw 4x4 q/c black laramie a/t
Smarty,Edge w/att hot,5" tbe BADP,K2 egr and cooler delete,ARP STUDS, Sun coast T/C 3, airdog2 165,shimmed rail,fire ringed, 2 JL13 w7's,JL1000/1(ridiculous)
Kick off this older thread, but maybe this is new to the problem...Mine is doing this, but the whine does not go away. It will only go away if you OPEN the W/S filter drain. If it is open, then the motor is totally silent and still pumps just fine. What does this mean? The unit is brand new.
2009 Ram 3500 Black Mega 4x4 Laramie; BlackMaxx w/OD Software; Shibby Engineering Stage 2 Horn; TV Delete, and Boost Tube; 5" TBE; 6" Tough Country Lift; 20" XD Series Rims with 37" Toyo MTs; AFE Mega Cannon Intake; AirDog 165; Amsoil BK25; Road Armor Front & Rear Bumpers with Line-X ...What is an EGR/DPF? more to follow...
Reason: edit
