Edge Question - Dodge Cummins Diesel Forum
Old 07-17-2011, 07:18 AM   #1 (permalink)
Louisiana Pipeliner's Avatar
Edge Question
I am running the Edge Juice with the attitude monitor. It is about 4 years old and the monitor has been going blank. The entire unit went out once. Anyone else have these problems? If I need to replace it, what programmer should I choose. I have an old delete and need to clear the codes and am running an MP-8 stacked. Any help will be greatly appreciated. Thanks
2007.5, Quad Cab, 4x4, 6.7L with 6 spd. Tranny. DPF, EGR, and EGR Cooler is MIA, ARP Head Studs, Edge Juice, MP-8, S&B CIA, 3250 Southbend DD Clutch with the Hydro upgrades. Dyno 486.25 HP and 898.00 FT. LBS!
Louisiana Pipeliner is offline   Reply With Quote
Old 07-17-2011, 02:10 PM   #2 (permalink)
Spody's Avatar
I had the same issue with my edge display a couple months ago. I'm pretty sure it was the connector for the display that was just a little loose or maybe had a bit of dirt/moisture in it. I pulled most of the connectors apart and cleaned them as well as checked power and ground connections. Display has been working fine ever since.
Try that out and see what happens. Hope it works for you.
'08 3500 Mega SRW, Laramie, Auto, 6" lift, 37" Toyo OC MT's on 20" Moto Metal 961's . Edge w/Att , MP-8, Sinister EGR/Cooler delete, Flo Pro DPF delete, Flo Pro DPF electronics, B&G tuned TCM
[SIGPIC][/SIGPIC]
'12 3500 CC LB DRW Laramie, Max tow. It's the wife's
Spody is offline   Reply With Quote
Old 07-17-2011, 02:30 PM   #3 (permalink)
seanth468's Avatar
iTrader Score: 5 reviews
If you buy an H&S or Smarty tuner you won't need to clear codes or need the MP-8. You could sell the MP-8 for a couple hundred and recoop some of the money back. Plus get better milage,less smoke,and lower egt's.
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Smarty,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Hankook 285 ATM RF10's.
seanth468 is offline   Reply With Quote
The Following User Says Thank You to seanth468 For This Useful Post:
Louisiana Pipeliner (07-17-2011)
Old 07-17-2011, 08:52 PM   #4 (permalink)
insane3639's Avatar
I have an insight and mine does this as well every day the unit will completely shut off and I sent the unit to edge they could not find a problem so they sent a whole new unit and cable problem still persists what me and edge came to a conclusion is that what is happening is that the obd port is losing the data communication cause the unit sees no data communication is shuts down and basically its not the units problem its my pickups problem
2007.5 SOLD.
2005 AUTO | 5"TBE | S&B CAI | SMARTY SR
insane3639 is offline   Reply With Quote
Old 07-17-2011, 10:53 PM   #5 (permalink)
Diesel Filled Veins!
Sandman76's Avatar
I had an Edge Juice CS that had a faulty display as well. The Edge Tech said it was a faulty display back light power supply. I sent my display in and they replaced the power supply so the display worked again. Problem was, the CS display wouldn't connect to the Juice once I got it back. Edge said to send it all in again including wiring harness. At that point I just decided to buck up and get the CTS Race Juice and everything is golden now.
You won't be able to upgrade to the Race Juice as that has very recently been discontinued but you could prolly upgrade to the CS if you like. If you're gonna change programmer, H&S or Smarty are the two to go with. If you like the display, Quadzilla makes a display that works with the Smarty
http://www.cumminsforum.com/forum/6-...d-control.html
And H&S makes display units for their products as well. The CS upgrade would be your cheapest solution I do believe (call Edge and you might get a good discount for a faulty Attitude display?).
NO K&N AIR FILTER LINK ATS Stage IV, Deleted, EFI Live By DaveMatthews, Edge CTS
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline   Reply With Quote
Old 07-17-2011, 11:27 PM   #6 (permalink)
This may sound ridiculous, but I had a similar problem. I was just about to send my Edge back, when I realized that it was my new sunglasses that were making my display look as though it was blank. When I took my glasses off I had no problem, the funny part was that I had made two twelve hour drives, delivering for my business before I figured out what was going on. Just a thought.
cwmegacab is offline   Reply With Quote
Old 07-17-2011, 11:37 PM   #7 (permalink)
Now that's funny, right there... I don't care who you are.
Old 07-17-2011, 11:39 PM   #8 (permalink)
Which H and S would best suit a day driver who just likes to have plenty of power?
Old 07-17-2011, 11:40 PM   #9 (permalink)
seanth468's Avatar
XRT unless you want or need digital gauges.
