Service required See dealer now!?! - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 12-27-2010, 02:28 PM Thread Starter
Bmega2500's Avatar
I got a "service required see dealer now" ding in the overhead display. Took it in and the dealer said there were no codes and nothing wrong. I have the rolling smoke diesel egr delete, H&S XRT and a 4" TBE. Runs fine but the damn overhead dings at me every 15 mins or so. Anyone have any ideas? Dealer guessed that i need to download the updated software from H&S? XRT is only about 8 months old. HELP!
2012 Ram 3500 CCLB Laramie, 4" TB MBRP, H&S XRT Pro, Fully deleted, 20x9 BMF Novakanes, 35x12.50 Toyo M/T's......SOLD
Bmega2500 is offline
post #2 of 37 (permalink) Old 12-27-2010, 02:31 PM
2rowdy's Avatar
It would probably help to go ahead and clear the codes. I know thare is none showing, happens occasionally with SMARTY and that fixes it. Sometimes I do it twice just for good measure.
THE GREAT WRECKING YARD IN TH SKY
2007.5, 6.7, ISSPRO rail pressure, boost, trans temp. Edge j/a,w/hot unplugged. extreme power puck ,SMARTY. ATS tranny. HTT 66/73/13-SS, DTT grid heater delete, ATS Co-Pilot
I have decided against going green
98 12v, 5 speed, ECLB, 4x4. Stock for now.
2rowdy is offline
The Following User Says Thank You to 2rowdy For This Useful Post:
itsabeast (12-29-2010)
post #3 of 37 (permalink) Old 12-27-2010, 03:24 PM
there have been many posts on this issue. how many miles are on your truck? I would try updating your XRT, both times I have had that show up in my ohd i updated my black maxx and it has fixed the problem.
2008 2500 6.7, AFE Mega Cannon, Black Maxx, BOD intake horn, RSD 5" tbe, Shibby boost tube, shibby cooler delete, southbend 3600 dual disk with upgraded hydraulics.
black08cummins is offline
post #4 of 37 (permalink) Old 12-27-2010, 03:39 PM
H&S Performance
H&S TECH's Avatar
Most commonly that message is due to the Crank Case vent filter needing to be replaced. Reset the message and see if it comes back:
Factory Vehicle Tech - H&S Performance
H&S TECH is offline
post #5 of 37 (permalink) Old 12-28-2010, 04:57 PM Thread Starter
Bmega2500's Avatar
H&S,
I just did the crankcase filter and reset the message.. that was "PERFORM SERVICE" This is "SERVICE REQUIRED" "SEE DEALER NOW" I will try to reset it again though.
post #6 of 37 (permalink) Old 12-28-2010, 05:11 PM
It happens to my truck every 2000 miles or so...somewhere in there, havent paid attention enough to figure out exactly when it happens, but it seems to be consistent. I just reload my tune with the Smarty and it goes away for another ~2000 miles
I read somewhere something about it automatically happening because the truck isnt going into regen (no DPF = no regen) and its an automatic response because the truck thinks something might be wrong, since its gone so long without a regen
Little does the big guy know, that stupid turd of a DPF is in the basement rotting away...
Khaki '08 3500 SRW Quad Cab SLT 4x4, Auto, 6.7L, 35x12.50 BFG M/Ts on 17" American Racing wheels, Access Tonneau, LINEX'ed bed, 5" TBE, H&S EGR/cooler delete, Smarty Jr
Blstr88 is offline
post #7 of 37 (permalink) Old 12-28-2010, 11:36 PM
08 6.7's Avatar
When that light came on my truck i replaced the CCV filter and Reset the timers on the XRT. Try that and reset the light with the Brake-brake-gas-gas trick.
08 6.7L G56 Quad Cab--H&S 5" TBE - EGR/Cooler Delete - MiniMaxx - AFE Mega Cannon II - Black Ops Intake Horn - Shibby Boost Tube - 305/65/17 Nitto Terra Grapplers
08 6.7 is offline
post #8 of 37 (permalink) Old 12-29-2010, 03:33 AM
Spody's Avatar
Did the dealer just use the key trick to see if it had codes or did they use the starscan ?
Either way, I can't believe they wouldn't reset it for you
On the plus side, they didn't seem to care that you had deletes and the XRT
'14 Black Edition 3500 Mega SRW Laramie, Auto, 6" BDS lift, 38" ATZ's on 20" Motometal 961's (black of course)
'12 3500 CC LB DRW Laramie, Max tow. It's the wife's
Spody is offline
post #9 of 37 (permalink) Old 12-29-2010, 08:03 AM Thread Starter
Bmega2500's Avatar
Im not sure if they used a starscan or not?.......Yeah the dealer is really cool about the deletes and they help me out whenever they can. The diesel tech is very good and knowledgeable.
post #10 of 37 (permalink) Old 01-04-2011, 08:29 AM
Bored_And_Stroked's Avatar
Got the Service Required See Dealer Now message yesterday for the 1st time. I have an 08 with just 29K on the clock with full deletes and H&S Black Maxx.
The truck has been deleted since new in 08 and has had a XRT at first and now a BM since then. Never have I got this message before. So I doubt it took my truck 28,000 miles to finally learn that the DPF fell off.
This is message is something different from "Perform Service" which deals with the CCV.
08 Inferno Red Dodge with Stuff
Bored_And_Stroked is offline
post #11 of 37 (permalink) Old 01-04-2011, 09:07 AM
I found this regarding resetting the "Service Required See Dealer Now"
My H&S Black Maxx will not turn off this warning by clearing DTCs.
This is what I found out about resetting the ECM:
1. Unhook both of your negative cables. Make sure when you lay them down, that they're not touching anything metal.
2. Unhook both of your positive cables. Lay them down so they don't touch anything metal.
(note: this is a good time to clean them up if they need it)
3. When you have all 4 unhooked, touch one pair of cables together (ie. driver's side pos. and neg.), then lay them back down...again making sure they don't touch metal. Do the same for the other side.
4. Reconnect your positive cables and tighten them.
5. Reconnect the negative cables and tighten them.
This process will reset the ECM. Learned that from a friend who is a dealer tech.
thread link OHC Service Required Reset - 6.7 Cummins Forum
Also regarding this just recently appearing, I think it has something to do with me disconnecting my negative cables to clean them over the weekend. I think that may have triggered this warning. It happened the first time I drove the truck after doing so.
post #12 of 37 (permalink) Old 01-05-2011, 06:06 PM Thread Starter
Bmega2500's Avatar
Will resetting the ecm effect the XRT? Will i need to reload my tune?
The Following User Says Thank You to Bmega2500 For This Useful Post:
Leo43 (08-20-2012)
