Small puddle of antifreeze under passenger side?? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 12-02-2010, 12:18 PM Thread Starter
Maddram's Avatar
I noticed a small puddle of antifreeze on the ground under the passenger side today. I tried to find where its coming from but could not see any obvious place. The overflow tank is not full or overflowing....same level it has always been.
I always run my blackmaxx on MILD and its set to defuel until cold coolant level is 180.
Is this a headgasket issue?
2009 Dodge 2500 4x4 6.7L Quad Cab, Alien Patrol winch bumper, Warn M15000 winch, PIAAs, S&B CAI, 5" TBE, H&S BlackMaxx, Overdrive trans tuning, H&S EGR & Cooler deleted, Glacier Diesel Street-Gate
Maddram is offline
post #2 of 12 (permalink) Old 12-02-2010, 12:57 PM
Southern Idaho VP
Boomer6104's Avatar
iTrader Score: 4 reviews
Check around the EGR cooler
Brian
Back to basics, 1994 Cummins 4" straight pipe, 5 speed w/splitter. Needs more air
1981 Volkswagen Rabbit 1.6 Naturally aspirated Diesel 50+mpg (Commuter Car)
Boomer6104 is offline
post #3 of 12 (permalink) Old 12-02-2010, 01:07 PM Thread Starter
Maddram's Avatar
My EGR and cooler are deleted...I checked the plugs that were in the delete kit and they are not leaking.
Maddram is offline
post #4 of 12 (permalink) Old 12-02-2010, 01:28 PM
Southern Idaho VP
Boomer6104's Avatar
Maybe a freeze plug or something
Brian
post #5 of 12 (permalink) Old 12-02-2010, 01:35 PM
check the coolant hose in the back side of the turbo, it is somewhat prone to leaking.
SOLD IT !!!! : 08 SPORT 6.7l 4x4 qc sb auto....smarty/b&g tuned , DIALED MOTORSPORTS suspended... 3.5", w/ 7100's. 35" toyo mt on polished stockers / HAD A TRX 4X4 PACK ?????
warlock06 is offline
post #6 of 12 (permalink) Old 12-02-2010, 02:19 PM
blackmega3500's Avatar
Where on the passenger side?
blackmega3500 is offline
post #7 of 12 (permalink) Old 12-02-2010, 02:26 PM
bthanks's Avatar
Check the hose that comes off the motor that used to go to the egr cooler. If its not tight it will leak and drip down your block, mine did it. Notice in the pic where it looks like its coming from, its actually coming from that hose. I ended up having to put another hose clamp on it along with that one to keep it from leaking.
2015 ccsb 4x4 g56. S369sxe 2nd gen man, ARP's . Efi live by ppei. 5" tbe, valair DD, Isspro: egt,boost,back pressure, fuel pressure and rail pressure. Helo maxx 8 20x10's with toyo mt 35x12.50's. Thuren/fox 2.0.
bthanks is offline
post #8 of 12 (permalink) Old 12-02-2010, 02:57 PM
907 cummins's Avatar
mine was leaking from the cheesy clamps that hold the egr coolent linebelow the coolant bleeder.can be seen from under the truck next to the oil filter.hope this helps.
09 2500 6.7 6 speed with all the delets and 5" ehaust . black max.s&b cia.6" lift with 37/1250r20 bfg km2s on jesse james outlaws
shibby boost tube.boost fooler.:finally got a new 3250 sb dd to get it all to the ground
907 cummins is offline
post #9 of 12 (permalink) Old 12-02-2010, 03:45 PM
700hp Club
4NEATR's Avatar
are you sure it's antifreeze and not just condensation off the AC condensor? When the temp drops a bit, and you are using the defrost, there will be a fair bit of water on the ground
2007.5 3500 MegaCab 4X4, Powered by Armor Inc, seats are stock....
4NEATR is offline
post #10 of 12 (permalink) Old 12-04-2010, 09:39 PM Thread Starter
Maddram's Avatar
Found it.....it was impossible to see where it was coming from while underneath the truck. But I was checking around the water pump because I know that was a problem on 07 and 08s, and I saw a drip out of the corner of my eye..........it was leaking where the overflow tube connects under the radiator cap. It would drip down and hit the lower rad hose then run off that to the ground.
I put a hose clamp on it and problem solved. Sometimes its the simple things and I never thought to check that hose
Maddram is offline
post #11 of 12 (permalink) Old 12-31-2010, 09:53 PM Thread Starter
Maddram's Avatar
Well I thought I had found it but the past week I still had a coolant puddle on the passenger side so I took it to the dealer to get them to replace the water pump under warranty and they did. No more leaks.
Maddram is offline
post #12 of 12 (permalink) Old 01-01-2011, 03:51 AM
IL Chapter VP
Onelongshot's Avatar
Location: Columbia, Illinois ALSO KNOWN AS THE COMMUNIST STATE OF CHICAGO
Water Pump Replaced
This is exactly what I went thru. I jsut found mine right off the bat when I saw it leaking.
Andy 2011 HO Ram 3/4 Crew Cab, Laramie, Short Bed, 4X4 Electronic T-Case, 68RFE, 3:73's, Snow Plow Prep, Line-X, Mopar Side Steps, Smarty Sr S67, Smarty Jr SJ67, Dodge_Made_It_Marco_Helps_Cummins_Shake_It.
Remember Elementary School "Cardboard Pizza and Tater Tots in the morning. The smell of Learning."
Onelongshot is offline
