dpf full - Dodge Cummins Diesel Forum
Old 04-05-2010, 01:18 AM   #1 (permalink)
jake13's Avatar
dpf full
Anybody have any ideas? Running 100 ohm resistors in place of egt sims and dpf full came up on overhead today. Been running them for about 2000 miles and havent had any problems. Think I need to build the pressure sim for the pressure sensor?
jake13 is offline   Reply With Quote
Old 04-05-2010, 08:49 AM   #2 (permalink)
Volcom18's Avatar
Unless you have an Edge to clear codes on startup, those pressure sensors will give you problems. Or you can buy a Black Maxx, XRT, or Smarty and not worry about any of that.
07.5' 6.7l G56
HardTimes Diesels Altered Diesel Wurks
Volcom18 is offline   Reply With Quote
Old 04-05-2010, 09:36 AM   #3 (permalink)
You're wrong! Get over it
dad2bike's Avatar
Code clearing is not required for the Pressure sim.
Pressure Sim is not required when using the 100 ohm resistors (per H&S)
If you are seeing a DPF full message with the 100 ohm sims, I suggest you take them off and test them with a meter. Then put them back on. Clear codes with a reader. Then see what you got. Sounds like either one has gone bad (open) or a bad connection at the connector.
Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.Dad2bike-installs-some-shibby-goodies..... DIY Deletes How-To
SNAFU
dad2bike is offline   Reply With Quote
Old 04-05-2010, 10:57 PM   #4 (permalink)
jake13's Avatar
Cool thanks for the input i will check them out and see whats up. Im eventually gona buy a smarty or bm. Money is pretty tight but i just started my new old job so it will be hooked up soon!!
Old 04-08-2010, 03:42 PM   #5 (permalink)
babs67cummins's Avatar
when you say pressure Sim is that the one kit you have to make for the pressure tubes. the connecter that is on the side of the tranny that is showin in your DIY delete link ?
08 Big Horn Quad Cab 6.7 Auto, afe stage 2 intake, 6in Aussies, 35in MT ATZ, 20in BMF novakane death metal black rims, Autometer Phattom II gauges, FloPro 4"tbe,BD tranny Pan, CCV delete, H&S minimaxx, Overdrive, H&S MaxxFlow Intake Horn, 4"boost tube, H&S rail plug, EGR/Cooler delete, Snow Watermeth, AFE intercooler, Airdog 165, Arp625
babs67cummins is offline   Reply With Quote
Old 04-08-2010, 03:49 PM   #6 (permalink)
dad2bike's Avatar
Yes.
As far as the DPF full message, I suggest contacting H&S. They are the ones that developed the use of the 100 ohm sims. Supposed to set the temp so High that the ECM will never ever try to regen, per their posts & the EGT sims tch article.
Tom
SNAFU
Old 04-08-2010, 04:05 PM   #7 (permalink)
Yes.
so H&S has a kit for that Pressure Sensor plug ? cause i just order the down pipe and delete pipe and the sims kit for the 3 egt plugs on the dpf but im confused on the one plug with the boost tube sensors. i heard they dont make a resister kit for that, that you have to make your own if you had the over head lamp come on that says dpf full.
Old 04-08-2010, 04:14 PM   #8 (permalink)
dad2bike's Avatar
No, I'm sorry if I confused you. Nobody makes the Pressure SIM. Shibby was working on something. Nothing yet though. The big issue is nobody makes the connector. The mating connector to the cable is ONLY part of the pressure sensor. Look in my signature at the DIY thread for how I built mine.
Tom
SNAFU
Old 04-08-2010, 04:29 PM   #9 (permalink)
alright. i looked that how you made the pressure senesor would it matter if i used a 120ohm 1/2watt and a 390ohm 1/2watt cause i couldnt find a 110ohm resister. and does it matter witch way you plug them into the plug?
Old 04-08-2010, 04:32 PM   #10 (permalink)
dad2bike's Avatar
How they are plugged in ys matters. Note in the pics I marked pin 1. I'm not sure if 120 ohm would work. You could put a 100 & a 10 in series to make the 110 ohms.
Tom
SNAFU
Old 04-08-2010, 04:45 PM   #11 (permalink)
so then the 110 resister is at the bottom as if you had the connector plugged/??
Old 04-08-2010, 04:59 PM   #12 (permalink)
dad2bike's Avatar
Look at these pics for guidance.
Rotate this picture to see Pin 1 is the one with the black mark.
Tom
SNAFU
