6.7 Cummins EGR delete issues - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 03-09-2010, 03:48 PM Thread Starter
Question 6.7 Cummins EGR delete issues
I have an 08 Dodge 6.7 Cummins that i have installed the dpf delete and edge race with no issues but now i installed the egr and cooler delete kit and the engine light stays on,any ideas?? please
Dodge_trucks is offline
The Following User Says Thank You to Dodge_trucks For This Useful Post:
Army SSG Ret. (02-02-2011)
post #2 of 25 (permalink) Old 03-09-2010, 03:54 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
depending on your flash level even the code clearing of your edge won't get rid of all codes. When you did the EGR and cooler deletes what did/didn't you unplug?
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 25 (permalink) Old 03-09-2010, 04:05 PM Thread Starter
I had no instructions with the kit so i just disconnected the 2 plugs that i had too to install the kit,do you have to remove the butterfly and unplug that plug as well???
post #4 of 25 (permalink) Old 03-09-2010, 04:09 PM
cummins2500hd's Avatar
try unplugging the wiring harness on the underside of the intake tube. My XRT stated that plug needed to be unplugged. Not sure if that is just and XRT thing or not though.
cummins2500hd is offline
post #5 of 25 (permalink) Old 03-09-2010, 04:11 PM
Originally Posted by Dodge_trucks View Post
I had no instructions with the kit so i just disconnected the 2 plugs that i had too to install the kit,do you have to remove the buterfly and plus also??
plug the one back in on the passenger side of the truck and zip tie it out of the way or bolt it back to the bracket. That'll clear a majority of them.
post #6 of 25 (permalink) Old 03-09-2010, 04:14 PM
without a programmer the throttle valve needs to remain plugged in so I wouldn't touch that one.... just remove the throttle blade if the truck tries to stall out after it is started.
post #7 of 25 (permalink) Old 03-09-2010, 04:18 PM Thread Starter
I do have the edge race programmer installed,should i try and unplug that one yet?
post #8 of 25 (permalink) Old 03-09-2010, 04:19 PM
My bad Kurt, I though the Edge Race may require this to be unplugged. I don't know though
post #9 of 25 (permalink) Old 03-09-2010, 04:33 PM
You're wrong! Get over it
dad2bike's Avatar
For a conventional EGR/DPF delete only the EGR is unplugged. Like Kurt noted the Cooler valve controller get's tied up out of the way. The BV stays plugged in. If you do code clearing, then you may have to remove the BV plate or the gear as there will be stumbling issues in cool temps when the truck tries to use the EGR/BV to assist in warm up.
Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.
SNAFU
dad2bike is offline
post #10 of 25 (permalink) Old 03-09-2010, 04:37 PM
You have an edge race "chip" or "tuner" it doesn't program anything unfortunately. Only programmers that get flashed in through the OBD-II port can unplug the throttle valve and the other goodies.
post #11 of 25 (permalink) Old 03-09-2010, 09:33 PM
throttlejocky316's Avatar
My edge would always throw the P0107 code, I could clear it but it would come back whenever I hit 4th gear. I was getting ready to buy a new sensor when I came across a deal on a smarty. I loaded up the smarty and the code disappeared and hasn't been back since. I have heard from other people that edge is known for throwing the p0107 code and can't clear it.
2011 F-350, 4x4, CC, LB, SRW, Camper Package, 6" lift w/ 37x12.50R20 Toyo R/T's, ATX Legend Wheels, Airlift Bags w/ Daystar Cups, H&S Blackmaxx, Flo Pro 5", No Limits Stage 2 intake, PMF Traction Bars
throttlejocky316 is offline
post #12 of 25 (permalink) Old 03-09-2010, 09:55 PM
PDRT
09dodgecummins's Avatar
the edge race aint that great about clearing codes from a dpf an egr delete its set up for it but i still wouldnt buy it id rather buy the smarty xrt or blackmaxx just my opinion
2002 5.9 6 speed, hot rod vp44, 150 horse injectors, air dog 150, valair 800hp comp dual disk, an a quadzilla adrenaline 4k with v2 pulse monitor 7 inch black single miter cut stack arp headstuds bd power super b special a htt quick spool 3 piece exhaust manifold hamilton 110# valve springs billet push rods s&b cold air intake
09dodgecummins is offline
