Efi live tuner question - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-18-2017, 07:18 AM Thread Starter
OK HAVE A REAL EASY QUESTION I HOPE..i HAVE A EFI LIVE TUNER ON MY 0 RAM 3500 DULLY QUESTION IS WHEN I GO TO THE TOW MODE TUNE DO I STILL NEED TO SWITCH TO THE TOW MODE ON THE TRUCK WITH SWITCH ON THE COLUMN? ND WHAT IS THE ADVANTAGE OF THAT TUNE? THANKS IN ADVANCE
DKFIRE12 is offline
post #2 of 5 (permalink) Old 04-18-2017, 08:57 AM
jimc3165's Avatar
I have a EFI live tuner from Calibrated Power. I am guessing they are all tuned slightly different (different tuners), that said the advantage for mine is additional HP, TQ and trans tuning and yes you should be in Tow/Haul when u are towing. Hope this is what u were asking and it helps
2007.5 RAM 2500 2WD 6.7
EFI Live tuning, Flo Pro Exhaust
jimc3165 is offline
post #3 of 5 (permalink) Old 04-21-2017, 07:18 AM
I'm assuming your referring to the factory (tow/haul) option. This is what helps save your transmission when pulling so yes you need to have this on when towing.
Sent from my SM-G900V using Tapatalk
coolbillster is online now
post #4 of 5 (permalink) Old 04-21-2017, 07:49 AM
Cummins Fanatic!
Fanman43's Avatar
I would imagine so. If you are towing, you should be setting your transmission to Tow/haul mode and switch to the tow tune (if desired).
As for the benefits of said tune. You should direct that question to whomever installed the tunes to your truck as they would know best for their own tune.
2007.5 DODGE RAM 3500 QCDRW - 6.7L CUMMINS FULL DELETE - H&S INTAKE HORN - STAGE II AFE COLD AIR INTAKE - FASS TITANIUM 95GPH - BEANS DIESEL SUMP - STRAIGHT PIPED - G56 6 SPEED TRANS - RANCH HAND BUMPER
'09 Chevy Silverado LTZ Z71 Stock as stock could be.
Fanman43 is offline
post #5 of 5 (permalink) Old 04-21-2017, 12:27 PM
08 Cummins
KhakiCummins's Avatar
The advantage of a Tow Tune is that it is going to give you more power than stock but is not going to be so aggressive that you have to worry about damaging things when towing.
Duane
2008 Ram 3500 QuadCab
Hamilton 103# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
2014 Jetta TDI 6 SPD Manual
KhakiCummins is offline
