I Did It!!!g56 Gear Rollover About Gone!!! - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 12-05-2009, 08:26 PM Thread Starter
roo
GOD IS GOOD
Well...finally got enough of the G56 Gear Rollover after the removal of my DMF, i took some advice and added 1 QT of Lucas Transmission Fix...It says it's compatible with all trans fluids and light duty manual trannys also. I removed a plug at the top of my tranny and just added 1 QT of the Lucas, did not remove any fluid...Now for the good part, i notice a tremendous difference, about 40 to 50 percent of the gear rollover is gone, it shifts great and even seems quiter in neutral..seems to have lost some of the neutral rattle....I'v only put about 20 miles on it since i added it, but so far im satisfied...im thinking about adding another half QT maybe a hole one..Ill report back when i get some more miles on the fluid addition..
2014 4x4 3500 Laramie Long Horn Mega, Aisin tranny w/ 4.10 gears, BDS 4" Lift w/ FOX 2.0 shocks, American Force 22" wheels, Nitto Trail Grappler MTs "325x50r22", Recon LED smoked cab & Bed marker lights, Road Armor Bumper w/warn 12k winch, Rigid 30" LED light Bar, CREE LED Fogs "Edge From RSD In The Near Future"
roo is offline
post #2 of 19 (permalink) Old 12-05-2009, 08:30 PM
txag09's Avatar
Keep us updated on how the noise is.
MINE 2007.5 dually somewhat stock
HERS 2001 2WD 2500 auto... it has a grid heater delete
txag09 is offline
post #3 of 19 (permalink) Old 12-05-2009, 08:33 PM Thread Starter
roo
GOD IS GOOD
Will do..can't stop smiling, that gear rollover was about to drive me crazy...I just hope the tranny keeps liking it..
roo is offline
post #4 of 19 (permalink) Old 12-05-2009, 08:40 PM
ken white's Avatar
iTrader Score: 6 reviews
Be careful if you overfilled it too much. You could be creating bubbles in the oil which reduces shear/lubrication and increases temperature...
2014, 3500 Cab & Chassis, Club Cab, Laramie Edition, AS69RC, with Freedom Quality Montana X bed - bone stock for now...
ken white is offline
The Following User Says Thank You to ken white For This Useful Post:
roo (12-05-2009)
post #5 of 19 (permalink) Old 12-05-2009, 10:50 PM
rbmedic75's Avatar
Subscribed
but question where or who did you get the idea to add the lucas fluid with out taking any out. I like the LESS rollover noise but like mentioned if the fluid level gets to high it will aerate and loose lubrication properties.
08 quad fully BODerized sold but i still get to drive and work on it for 6 months
2012 Mega Laramie Lonhgorn has arrived Chomping at the bit to get a FULL MAKEOVER
2012 Acadia Denali its hers I dont get to play with it
rbmedic75 is offline
post #6 of 19 (permalink) Old 12-05-2009, 11:03 PM
DRT086.7's Avatar
iTrader Score: 18 reviews
I gotta go buy me a quart tommorw!
'97 RCLB 12v NV4500
SOLD-'08 6.7 6-spd QCSB 740hp/2000tq
-'07 QCLB 5.9 NV5600 Bored, cammed, twinned
DRT086.7 is offline
post #7 of 19 (permalink) Old 12-05-2009, 11:25 PM Thread Starter
roo
GOD IS GOOD
I had a buddy that had read somewhere that some guys where removing a sensor up top of the tranny and adding 2 qts due to some rear bearing oiling issues. Some guys had reported rear bearings burning up. They were saying the fluid level from Chrysler was not adaquite and all was good after the fluid level increase... not sure if thats the case with the G56..(May not be a bad idea to drop a qt before adding the Lucas)
roo is offline
post #8 of 19 (permalink) Old 12-06-2009, 01:40 AM
rbmedic75's Avatar
very interesting definately worth checking out thanks for sharing bud
post #9 of 19 (permalink) Old 12-06-2009, 01:58 AM
Recovering Post Whore
HardcoreDiesel's Avatar
Wink
Hmmm........ http://www.cumminsforum.com/forum/6-...ml#post2315158
HardcoreDiesel
2009 5500 C&C Laramie QC 6.7L 4X4 G-56 4:44's and ALL DELETES DONE @ 8 MILES!! BRAYDEN @ FLEECE PERFORMANCE EFI LIVE DYNO TUNED, Fleece VGT Cheatah, Fleece coolant bypass, 5" Turbo Back Magnaflow Exhaust, Banks Intercooler & Tubes, Pusher intake horn, AFE Stage II, Dipricol Guages, Accuride 19.5's & Valair 3850# SFI Billet/Bronze Insert DD Ceramic/Solid Hub/12 Button
550 H.P. & 1200 ft. lbs
HardcoreDiesel is offline
The Following User Says Thank You to HardcoreDiesel For This Useful Post:
roo (12-06-2009)
post #10 of 19 (permalink) Old 12-06-2009, 02:28 AM Thread Starter
roo
GOD IS GOOD
Originally Posted by HardcoreDiesel View Post
Your the Man
roo is offline
post #11 of 19 (permalink) Old 12-06-2009, 02:34 AM Thread Starter
roo
GOD IS GOOD
Fyi
I paid $12 at Napa for a Qt....It was a pain to get in their, had to do some rigging with some tube and heated the fluid in some hot water to help it flow a bit better (Very Thick) but all was well worth it!!!
roo is offline
post #12 of 19 (permalink) Old 12-06-2009, 04:08 AM
Turbine TA/Steam/Gas/Nuke
WSTEPHENS's Avatar
When the G56 was first introduced it had issues with failures and a hold was put on building anymore trucks with the manual until the cause was found to be not enough oil, so they raised the level and that failure stopped.
Bill Stephens
2012 3500 Black Laramie Limited, Crew Cab. 68RFE 6 speed, 4x4, 350/800.
WSTEPHENS is offline
The Following User Says Thank You to WSTEPHENS For This Useful Post:
roo (12-06-2009)
