P2454 & Smarty - Dodge Cummins Diesel Forum
post #1 of 30 (permalink) Old 07-06-2009, 03:44 PM Thread Starter
P2454 & Smarty
Trying to get code free and I still get this one, have re-installed twice, checked everything and can not get rid of this code. When I clear the code with the smarty it will not take it away. You can check for DTC's after you delete it and it is still there. Any advice? Thanks for your help I know I have been posting a lot, thanks for all your help.
HW
hw713713 is offline
post #2 of 30 (permalink) Old 07-06-2009, 03:50 PM
Unreconstructed
Alabama Mud Machine's Avatar
P2454 = Diesel Particulate Filter Pressure Sensor A Circuit Low
Make sure everything it says to unplug is unplugged, and make sure everything that is not supposed to be unplugged, is plugged in.
Also make sure if you're deleted that you have the DR12ME software downloaded onto your Smarty to be running code-free.
2011 Chevrolet 1500 LT Z71 Crew - 5.3 / auto, Ranchhand guards, 275//70/18 Toyo MT's
2007.5 Ram 2500 QC/SB 4x4 - 6.7 / 68RFE - EFI Live tuned, and a bunch of other stuff
1996 Ford F-250 4x4 - 7.3 PSD / ZF-5 - Awaiting built 12V swap
Special thanks to:
, Shibby Engineering, Black Ops Diesel, Motorsport Diesel, EFI Live, & Hardway Performance
Alabama Mud Machine is online now
post #3 of 30 (permalink) Old 07-06-2009, 03:51 PM
seanth468's Avatar
iTrader Score: 5 reviews
Are you still using the sims?
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Anarchy,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Toyo AT2's.
seanth468 is offline
post #4 of 30 (permalink) Old 07-06-2009, 04:49 PM
evan4434's Avatar
I think with the Smarty you need to have the pressure sensor hooked up, but the hoses removed from the pressure sensor. The P2454 is when you have the pressure sensor electrical connection unplugged. The other option is to have DIY resistors in place to fool the connection and make it think it is connected, but either way you have to have to connection made.
3500 2004.5 Cummins
evan4434 is offline
post #5 of 30 (permalink) Old 07-06-2009, 04:50 PM
Unreconstructed
I believe you do have to have the pressure sensor hooked up.
Good call evan...That completely slipped my mind.
Special thanks to:
post #6 of 30 (permalink) Old 07-06-2009, 04:59 PM
Rollin Smoke Diesel.com
Rollin Smoke Diesel's Avatar
iTrader Score: 19 reviews
In speaking with Heath, he does not have sims and the pressure sensor is connected and hoses unplugged. He has tried to reinstall the program once and still getting the code.
James
RSD
Contact us for all your diesel performance needs!
219-851-1195 Monday-Sat 8am-5:30pm CST, online ordering 24/7, Please Email
no PM's
Rollin Smoke Diesel is offline
post #7 of 30 (permalink) Old 07-06-2009, 05:06 PM
Unreconstructed
James
RSD
He could try uploading the Smarty with the program off the website again...
It's just another one of my dumb idead, but you never know, it might help? LOL
BTW, I didn't ignore your PM earlier, we've just been busy as hell at work, and I just called you a second ago, but you didn't answer, so I left you a message. Holler back at me, I'll be at work for a while.
Special thanks to:
post #8 of 30 (permalink) Old 07-06-2009, 05:45 PM Thread Starter
Thanks guys for your help, I will check everything again. Sorry I had to be away for a little bit, I will keep you updated.
HW
hw713713 is offline
post #9 of 30 (permalink) Old 07-06-2009, 05:46 PM Thread Starter
when you say hoses unplugged, I still have the rubber ones on there taped up, however the steel lines are gone, do I need to remove them?
hw713713 is offline
post #10 of 30 (permalink) Old 07-06-2009, 05:48 PM
Super Mod
jpark's Avatar
They are not taped together are they?
2006 2500 Mineral Gray 4x4
jpark is offline
post #11 of 30 (permalink) Old 07-06-2009, 06:02 PM Thread Starter
They are not taped together, however I re-installed for a 3rd time and am finally code free!!!!! thanks for all of your help to everyone. James at RSD is a top notch hand, I would highly recommend him to all. I will give a smarty write up after a few trips around the block. Thanks.
HW
hw713713 is offline
The Following User Says Thank You to hw713713 For This Useful Post:
Rollin Smoke Diesel (08-22-2009)
post #12 of 30 (permalink) Old 07-06-2009, 06:05 PM
IL Chapter VP
Onelongshot's Avatar
Location: Columbia, Illinois ALSO KNOWN AS THE COMMUNIST STATE OF CHICAGO
congrats hope it works out well for you.
andy
Andy 2011 HO Ram 3/4 Crew Cab, Laramie, Short Bed, 4X4 Electronic T-Case, 68RFE, 3:73's, Snow Plow Prep, Line-X, Mopar Side Steps, Smarty Sr S67, Smarty Jr SJ67, Dodge_Made_It_Marco_Helps_Cummins_Shake_It.
Remember Elementary School "Cardboard Pizza and Tater Tots in the morning. The smell of Learning."
Onelongshot is offline
