Boost Fooler? - Dodge Cummins Diesel Forum
Old 03-22-2009, 05:11 PM   #1 (permalink)
G-NOTE's Avatar
Question Boost Fooler?
Ok I am trying out the boost fooler with progammers and ran into something...
I am using the superchips cortex on the tow setting, my dashhawk reads spikes of 33psi and holds at 31...
I installed my boost fooler not expecting a change on numbers, but to actually feel or hear more boost...
Insted it now spikes at 25psi and holds 23...
Sounds backwards to me...
Not to mention feels slower when installed...
Does it not work with the cortex???
*2010 Ram 2500 4x4 6.7 Cummins: Smarty S67me (130hp setting), 4" DPF delete, 4.5" Rancho Lift, 35" Pro Comp Xtreme A/T, 20x10 BMF NovaKanes, 6k Hi/Low Hid's, Amp Reserch Steps
G-NOTE is offline   Reply With Quote
Old 03-22-2009, 05:19 PM   #2 (permalink)
SRT6.7's Avatar
your dash hawk will not read corectly cause the boost fooler it fools the computer reading thats why a mechanical gauge is needed for accurate readings with a fooler.... But mine i noticed more turbo noise and ALLOT more throttle response and got up and went way faster
TOY=07.5 SRT6.7 built balanced big valves +more
FAMILY=07.5 mega 68rfe, EFIBYRyAN V2, 5"SS, HID's,20" fuels on 35s, thuren fox
WORK=02 5.9 2500 few goods
SRT6.7 is offline   Reply With Quote
Old 03-22-2009, 06:17 PM   #3 (permalink)
G-NOTE's Avatar
Question
Yeah but why would it decrease the boost???
I was running spikes of 33psi and holds at 31psi before the install...
So that shouldn't have changed and I should have felt the difference insted of it getting worse...
Old 03-22-2009, 06:56 PM   #4 (permalink)
SRT6.7's Avatar
If you dont have a mechanical gauge no other gauge will read right like edge pmt or dash hawk... people are talking about having lower boost numbers then before though in the other thread i in fact didnt feel lower boost or anything and i dynoed it and showed increase and brought it on faster!
Old 03-23-2009, 11:25 AM   #5 (permalink)
G-NOTE's Avatar
Wink
Ok pulled the Cortex off, running just the boost fooler...
and it feels good, alot better than before...
But still boosting and holding 23 psi spikes at 25, thats the same as it was with the programmer...
Programmer by it self spikes at 33 and holds 31psi...
So I think its safe to say it doesn't work with the cortex!!!
Old 03-23-2009, 03:12 PM   #6 (permalink)
BOOOST's Avatar
Dude, its your dashhawk reading inaccurately. Get some real gauge, than take a look.
Why would it read lower, simple, the boost fooler tells the ECM its lowwer than it actually is, the ECm compensates and adds more boost.
Have you tried one of your 5 other tuners? All those tuners and no REAL gauges? get some gauges and stop buying tuners.
- 08 MEGA - KORE - FOX - CARLI - THUREN - TOYO - AFE - SMARTY - LINEX - RETROSOLUTIONS - ARP - GDP - IISB66 - BD -
BOOOST is offline   Reply With Quote
Old 03-23-2009, 05:07 PM   #7 (permalink)
G-NOTE's Avatar
Exclamation
I HATE mechanical gauges...
I hate to run them and I hate the look, down here everybody will be trying to race me...
I understand what you guys are saying about the dashhawk not getting an accurate reading and YES its doing this with the other programmers, but I haven't tried EDGE yet...
But if the DASHHAWK is reading 31psi withthe superchips installed then in theory that number should not change with the Boost fooler installed... Correct or NOT???
But the number is changing, with both the Cortex and Boost fooler installed it is only holding 23psi, so even if the DASHHAWK doesn't see the extra 10-12psi that its adding, its still better to just run the Cortex by itself and hold at 31psi...
So at best with both of these units I am seeing a 4psi gain!!! WOW
But with the Cortex at Extreme I can hit 36psi and hold 33psi, so really I am gaining 1 psi running them together...
Old 03-23-2009, 05:38 PM   #8 (permalink)
08 Cummins
KhakiCummins's Avatar
I'm not familiar with the Cortex, is it a downloader or a box?
Duane
2008 Ram 3500 QuadCab
Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive by me thanks to Zach, SB 3250 DD
KhakiCummins is offline   Reply With Quote
Old 03-23-2009, 05:51 PM   #9 (permalink)
G-NOTE's Avatar
Unhappy
Its an OBD II Downloader...
Old 03-26-2009, 01:31 PM   #10 (permalink)
Coldaim's Avatar
what do you not understand about your not seeing true boost if the boost fooler dosent tell the computer its low on boost then it will never hold the wastegate to higher boost and you should always have mechanical gauges when your moding your truck.. look at it this way if a sensor for the computers boost reading messes up and tells the computer you have no boost and your chip overfuels and your wastegate never opens and you blow your headgasket then how stupid are mechanical gauges then when you could have just shut er down
04 Chevy Corvette. LS1 6 spd man coupe black on black
95 CTD excab long bed leveled and on 35"s silencer ring and fuel plate MIA and a 5" stack and gauges on pillar pod
Coldaim is offline   Reply With Quote
Old 03-26-2009, 01:39 PM   #11 (permalink)
Backhoe Man's Avatar
anything that reads off obd2 will not read correctly with a boost fooler I dont care if it is edge or what. I picked up nine pounds with the boost fooler The more fuel you have the better it will work
2008 3500 G56, pretty much stock
Thank You Left Coast Diesel
Backhoe Man is offline   Reply With Quote
Old 03-26-2009, 01:40 PM   #12 (permalink)
Blacksmoke07's Avatar
check, and checkmate
Maroon 01' 6 Spd, ECLB, Southbend 3250 DD, Edge comp, 275 injectors, 5" - 7" stack, Airdog II, 2" leveling kit, S&B Intake, S&B Intake Manifold.
Next: Headstuds, and Turbo
Blacksmoke07 is offline   Reply With Quote
