easiest place to tap for pressure sensor resistors
i'm trying to figure out where would be the easiest place to tap into the harness to install the resistors to fool the exhaust pressure sensor like in many prev. posts. i understand how to wire it but where do you guys usually tap them in at.
2008 2500 6.7 auto. edge juice box and 4 inch cold air inlet on bottom of air box.14.61 @ 91 mph in 4wd. H&S stage 2 dpf delete kit. Now it smokes!
I don't tap them. I make the kit so it plugs into the plug. I then tape it up for water protection. Look in the DPF & EGR deletes on a budget thread in the powertrain section. A picture is about 2 or 3 posts in.
__________________ Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.Dad2bike-installs-some-shibby-goodies..... DIY Deletes How-To
Linky wood be nice.
2007.5, 6.7L 2500 4x4 LARAMIE- H&S Performance MCC Mini Maxx with OverDrive, H&S Maxx Flow intake horn, H&S 4" boost tube, H&S 5" TBE straight piped, 3 ATS TC's and 2 ATS Stage 4 68's cooked, SunCoast M3GA68 Big Dawg now, HTT stainless steel 66/71/16 turbo, HTT stainless steel 3rd gen manifold, ARP 625's, Industrial Injection Stage 2 CP3, FASS 150/150, Snow Performance water methanol injection, Capped rail, AFE Mega Cannon, DiPricol Gauges, 4" Superlift/BDS, BOD CA's, GDP X-Bars, GDP CCV Delete, Bushwacker flares, Mag-Hytec diff covers, 20x14 American Force Independence, 33x13.5 Mickey Thompson ATZ's, RDX Billet Grill, Line X, 20% Tint, 12,000K HID's.www.hsperformance.com
Where do you get the wire couplers to make your pigtail from then?
In my case I've scrouged up some printed circuit pins that I crimp on. I've seen others take regular fork style crimp on terminals and cut 1 of the forks off of each.
I'm NOT searching for those pics and links. I think they may be in the budget thread.
thanks guys. i got it done today. i was picking up parts at the ford dealer today and i asked them if they had any kind of small spade connectors for in the haness's, sure enough , the parts guy came out with almost exactly the right size terminals in his hand. they had about 3 inches of wire attached to them. so a soldering i went. i put di-electric gree in the connector and pluged in the wires, then put the connector and resistors in a small plastic bag and zip tied it tightly.no more check eng light.
sorry i don't. i think he said it was a volkswagon peice though. they have vw too. on the bill it is just a generic pigtail.
