clearing codes on egr unplugging - Dodge Cummins Diesel Forum
Old 01-29-2009, 11:00 AM   #1 (permalink)
MATTIAC's Avatar
i just want to get this straight, did I read on here a while ago that if you have a unti to clear codes, you dont want to clear the code of the EGR being unplugged because it will make it act funny? so should i plug it back in until i get the delete, or was I just imaganing I read that.
08 Elect Blue 6.7 Mega. 3500. Sunroof. Leather.VES. 6" Lift. 37x13.50-20 Toyo M/T/Eagle 064B wheels.. 5" TBE w/ 6" Tip. H&S Black Maxx. S&B CAI. NADP Heavy Hauler. Starter/Alarm. 6000k HID HI/LOW & Fogs. Kenwood DNX9140 w/ subs.amp.speakers. BOD Intake Horn and EWG. Shibby Boost tube.Triple Pillar w/ Boost & Rail Pressure.
MATTIAC is offline   Reply With Quote
Old 01-29-2009, 11:09 AM   #2 (permalink)
howdy's Avatar
deffinatly. when you unplug the egr you are in essence stoping the servo from opening and closing. so when you start the truck the ecm looks for the servo motion and the temp increase. when it does not see this that is where you get your check engine light from. then when your light comes on the truck look's for a fix. it will try to use old files from the computer to correct the problem this often causes Regen.... now if you have a dpf delete there is nothing to catch the 4th injection cycle then it comes out the back of the truck in a big white haze fogging out the whole neighborhood ..now when the truck does a regen it is looking for the catilist temp to raise quickly to burn the soot out of the dpf .. but since there is no dpf the truck does not see the temp it wants so it will slip into limp mode..these are all possibilitys of unplugging your egr. even when you do unplug your egr it does not stop completely the soot for recirculating into the truck. it stops most but not all. now if you clear codes you have much less chance of this happening because the truck will think the dpf is broken so it will not want to do any regen...but still possible.
if i can help you get some code free electronics let me know
i hope that helped a bit
howdy is offline   Reply With Quote
Old 01-29-2009, 11:18 AM   #3 (permalink)
LittleOleHotShotter's Avatar
egr gone, unplugged, codes cleared, runs like a wet dream past 90,000 miles
TRUCK IT TRANSPORT
http://www.cumminsforum.com/forum/07...-part-off.html
LittleOleHotShotter is offline   Reply With Quote
Old 01-29-2009, 03:23 PM   #4 (permalink)
6.7megamax's Avatar
So howdy what your saying is DO clear the egr code on startup? I just want to make sure cause that's what I thought all along as well but everyone else said my truck wouldn't run properly.
07 Megacab 6.7,Laramie,Custom 11" lift, 40x20 toyos ,20x14 Octanes,S&B CAI, 4" turbo backEGR MIA,Smoke switch HID Head & fogs Competition Built Subs & Enclosure, Pioneer AVIC-X910, 9" headrest monitors
6.7megamax is offline   Reply With Quote
Old 01-29-2009, 03:34 PM   #5 (permalink)
So if I unplug my EGR do I need to let my Edge clear the codes everytime I start my truck?
'08 3500 SRW Patriot Blue Mega Cab, 6.7L, 6 Speed Auto, 5' H&S TBE W/6' Chrome Tip, Edge Juice W/Add, Airlift Air Bags
(SOLD) '98 2500 12v, 70hp Injectors, Fuel Plate Slid, 4' TBE, Airlift Air Bags
MegaTruck2008 is offline   Reply With Quote
Old 01-29-2009, 03:43 PM   #6 (permalink)
howdy's Avatar
yes sir clear the code
Old 01-29-2009, 03:45 PM   #7 (permalink)
How much does an EGR delete cost?
Old 01-29-2009, 03:49 PM   #8 (permalink)
howdy's Avatar
egr delete and the electronics is 975
Old 01-29-2009, 07:59 PM   #9 (permalink)
Riddler6.7's Avatar
my truck doesnt run right when i clear the code... neither did a few other ppls
runs normal when i do NOT clear the code, just give it a try and see how your truck reacts
2007.5 QC SWB 4x4
6.7CTD, 68RE, Inferno Red, Big Horn
and i aint tellin the rest
Riddler6.7 is offline   Reply With Quote
Old 01-29-2009, 08:16 PM   #10 (permalink)
Diesel Poser
slagburn's Avatar
Do you know what flash you're on? I know at least one person AX who mentioned that his truck runs different with the codes cleared.
I'm on AU and can't detect a difference.
07.5 2500 - 4x4 - faster than a few things slower than many others.
slagburn is offline   Reply With Quote
Old 01-29-2009, 08:19 PM   #11 (permalink)
Riddler6.7's Avatar
i BELIEVE i have AV flash... they never updated the sticker, it stilll says AU, but i had it flashed 1 time since then, i MAY have the AX , most likely AV or AX
2007.5 QC SWB 4x4
Old 01-29-2009, 08:38 PM   #12 (permalink)
jrader5679's Avatar
How much for just the electronics? Mine runs fine and the only time i delete the codes is when the overhead starts going off and won't shutup but that only happens about every tank and a half of fuel.
Jason
07.5 6.7L 2500 SLT QC 4X4, G56, Brilliant Black, Thunderroad, AIRAID stage 2, 4" H&S TBE, EGR & Cooler delete, 7" tip, Smarty Jr 28ME
jrader5679 is offline   Reply With Quote
