i just installed a juice with attitude in my 2008 2500.. when i go full throttle in extreme mode the truck bucks crazy.. i dont know what to do.. the egt temps are showing 1500 then they back down to 1420 . i done a performance test 1/4 mile . the truck showed a 15.7 @ 90 mph..what could be wrong???.. the truck is 100% stock other then the edge and only has 1800 kms on it. thanks for your help...
what do you mean by bucking.....is it like kinda stalling....if so , that level 5 extreme is basically draining the fuel out of the rail....time to upgrade fuel system.
try to move ur max egt to 1550 and then move ur max boost to 45psi..... u may have ur defueling settings set to low............... or a better way, push enter twice and a screen will pop up and then hit enter again. This will shut off ur saftey features for 1 minute.... then run it WOT and see if it bucks.............. if it doesnt buck its that ur max settings are to low
i jut read the monitor and it said that backdown was 37%... what does this mean?...is this defueling? iam new to diesels, thanks for all the help..
2008 ram 2500 slt quad cab, 6.7 . 6 sp auto,4.10 gears, edge juice w/ attitude..+ hot unlock..ts-performance mp8..mbrp 4 inch stainless duals with 6 inch tips. 2 inch hbs leveling kit. in level 6 best et 13.9@100 mph before the mp8 on april 29/09
i just went out and warmed up the truck...i tried a full throttle run and checked the guages again. backdown was at 100%. i raised the egt setting to 1550 and the boost to 45 , i tried another run and now the truck is fine . backdown was only 5%, i guess this is normal..yhanks for all your help..this site is a awesome place for info...
