Engine light - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7L Non-Powertrain
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 05-30-2012, 10:21 PM   #1 (permalink)
Engine light
The problem started after i did a after market alarm. Every thing works fine from remote start to the auxiliary functions. I did do the sentry start bypass (key in a box). Now a little red light flashes by the speedo. Any ideas?
alaska1996 is offline   Reply With Quote
Old 05-30-2012, 11:04 PM   #2 (permalink)
i scanned for codes but nothing came up. It makes an obnoxious clicking when it turns on. It comes and goes and sometimes the tire light comes on with it but stays solid. Then both will go away for ten or so miles.
Old 05-31-2012, 09:35 PM   #3 (permalink)
grporter's Avatar
Where did you pull power for the alarm system? Possible your power draw is interfering with a signal and the ECM is getting invalid voltages. These trucks are VERY sensitive to changes in wiring. If you can, pull constant 12v from the battery (fused of course) and if you need switched 12v use the power port under the dash.
2010 CCSB 4x4 Big Horn. Smarty,Reunel bumpers,Warn winch,285/75-17 Terra Graps,reverse leveled,F&R cameras w/Lockpick CHR550,Airlift bags
2012 VW Golf TDI super commuter
grporter is offline   Reply With Quote
Old 06-01-2012, 12:47 PM   #4 (permalink)
I have a hot coming from the battery. I did a relay that taps into the ignition wire. Could that be the cause
Old 06-01-2012, 02:02 PM   #5 (permalink)
Yahooligan's Avatar
I'm no expert, but it sounds like the alarm is causing communication problems on the CAN bus. How does the immobilizer work, what is it tied into? The CAN bus ties all the various modules throughout the truck together, it's fairly common for aftermarket devices like alarms and stereos to cause problems if not properly installed or designed to work with CAN bus systems.
2007.5 3500 MegaCab SLT SRW 4x4 6.7L, 68RFE w/ Mag-Hytec, XRT Pro, Diamond Eye DPF Delete, leveling kit w/ Bilstein 5100s, SnugTop Rebel shell, Insight CTS, Hell Bent Steel SBS - SOLD
Yahooligan is offline   Reply With Quote
Old 06-01-2012, 07:42 PM   #6 (permalink)
the immobilizer breaks the ignition wire. If the alarm goes off, or if i press a button, it energizes the relay separating the contacts. so it kills the starter. I've also tapped an auxiliary to the cargo light button. The door locks are tied into the alarm. The door sensor are tied into the alarm. The siren is external, the alarm light is external. And the parking lights are set to flash With the alarm.
The light coming on is number 13 in the Manuel on page 188. It only comes on when i'm driving forward faster than 30. Every thing is normal when i'm puttin around or idling.
Old 06-01-2012, 07:54 PM   #7 (permalink)
i would like to know more about the CAN bus. The alarm is a Viper Responder 350 2-Way.
Old 06-05-2012, 07:13 PM   #8 (permalink)
still have the light any one have any more advice that could work. Would a video work.
Old 06-05-2012, 07:49 PM   #9 (permalink)
grporter's Avatar
Have you contacted tech support for Viper? They may have some info if there's a known problem with certain vehicles.
Old 06-05-2012, 07:50 PM   #10 (permalink)
grporter's Avatar
What does the manual say about light #13? What is it saying causes that light?
Old 06-06-2012, 03:11 PM   #11 (permalink)
13. Security Light
The light will flash rapidly for approximately 16 seconds
when the Vehicle Theft Alarm is arming. The light will
flash at a slower rate after the alarm is set. The Security
Light will also come on for about two seconds when the
ignition is first turned ON.
2008 Dodge Ram 6.7 2500 TRX4*4
Mini Maxx;DPF & EGR delete w/cooler bypass;HHO injection;2.5in lift;K&N filter air scoop;Ranch Hand Sport Front/Back Bumper;Rancho RS9000XL Shocks
Old 06-06-2012, 04:27 PM   #12 (permalink)
I contacted viper and they said they'll get back with me, so no luck there
