Originally Posted by dhaile
Hello all.
My sticker on the door shows 40psi in rear to be correct psi. What are you guys running in a dually when towing over 10k? I am used to a 2500 and 80psi on those. Duals is new to me.
thanks
Make sure you're looking at the right sticker, there are usually two. The white placard lists GAWR and GVWR as well as tire PSIs needed to run those loads. The other sticker is a supplemental sticker showing light-load PSI. At least, there are two on my 3500. Yours should be similar, showing light-load and heavy-load PSIs.
2007.5 3500 MegaCab SLT SRW 4x4 6.7L, 68RFE w/ Mag-Hytec, XRT Pro, Diamond Eye DPF Delete, leveling kit w/ Bilstein 5100s, SnugTop Rebel shell, Insight CTS, Hell Bent Steel SBS - SOLD
