Track bar problems!! - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 14 (permalink) Old 05-19-2010, 07:26 PM Thread Starter
Big_Rubber's Avatar
Hey guys so I got this track bar
Pure Performance Heavy Duty Adjustable Track Bar
Not from George, but got it used on Ebay with very low KM's. Went to install it today and turns out it hits on the frame side where the actual back side of the bracket is so I can't even put it up to the bolt hole. Now the thing never came with instructions but I have the 3" kore Lift and I thought this would be the perfect addition to re center my axle but I ended up having to throw the OEM trackbar back in good way to waste an hour ugh... anyone got any ideas?
The Arm of the trackbar is hitting the Back side of the Bracket below where the bolt hole is. Here is a Paint diagram... forgive me for my Crap art skills, I don't paint, I wrench lol.
2012 Ram 2500 Limited Mega White -Carli 6" 2.5, Full Carli Leafs, 17" method DS w/ 37" Toyo MT, Coming soon: Carli Balljoints, Carli Axle Truss, Carli 3.5" setup
Big_Rubber is offline
post #2 of 14 (permalink) Old 05-19-2010, 07:39 PM
blacksmoke6.7's Avatar
Is it upside down Just kidding, post up a real pic and maybe someone can help.
2012 3500 DRW LONGHORN 6.7 (CARLI AND TOYO 285/75R17 UNDERNEATH, RIGID LIGHTS, WESTIN HDX, SUPERWINCH 12.5iSR, 60Gallon RDS Fuel tank)
SOLD 07.5, 2500 6.7 Mega
blacksmoke6.7 is offline
The Following User Says Thank You to blacksmoke6.7 For This Useful Post:
Big_Rubber (05-19-2010)
post #3 of 14 (permalink) Old 05-19-2010, 07:44 PM
Dont know if it makes any difference, but the listing in 8LUG says
"* Not recommended for stock trucks or lifts less than 4"
**Recommended for lift heights 6.0" or greater with a track bar drop bracket that utilized the OEM track bar. In this situation it will support up to 10" of lift."
post #4 of 14 (permalink) Old 05-19-2010, 07:46 PM
Muddy H2O's's Avatar
What is the length of it Carli recommends 39.25 inches Eye center to center for up to 3 inches of lift. If it appears too long or too short the axle needs to be moved one way or the other.
2008 Laramie 2500 DPF Cat delete, Edge Juice, AFE intake, 4inch Turbo back FloPro Exhaust, Carli performance 2.0, Carli control arms XD series 18" addict w/295/70R18, Nitto Trail Grappler MT,s
Muddy H2O's is offline
post #5 of 14 (permalink) Old 05-19-2010, 08:30 PM Thread Starter
Big_Rubber's Avatar
Yeah guy I bought it off said he had a 2" coil spacers on his and it worked, so I assumed I shouldn't have a problem with my Kore 3" lift, I'll try and get a pic this weekend, gotta call pure performance tomorrow too
post #6 of 14 (permalink) Old 05-19-2010, 08:31 PM Thread Starter
Big_Rubber's Avatar
I made the bar the same length as the Factory, it just doesn't have the dog leg that the factory one does so it hits on the frame and it doesn't look like 1" of extra lift would fix the problem im having
post #7 of 14 (permalink) Old 05-19-2010, 08:32 PM Thread Starter
Big_Rubber's Avatar
I thought of that lol so flipped it around and still no dice
post #8 of 14 (permalink) Old 05-19-2010, 08:44 PM
You might be better off just getting a 3" track bar drop bracket and running your factory track bar
post #9 of 14 (permalink) Old 05-19-2010, 10:58 PM
That Truck Guy
Skyd Ram's Avatar
iTrader Score: 8 reviews
Jordan,
I thought that you had a Carli bar?
Anyhow, that bar should only be used with a track bar drop bracket and 4" or more of lift for the reason that you have already discovered.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Dynatrac
Synergy Suspension | Fox Shocks| aFe Power | S&B | SOTA Wheels| Air Dog | Amp Steps
TRUCKBOSS Sled Decks | Spicer | ARP | REV-X | RIGID Industries | Baja Designs
888-886-2480
Skyd Ram is offline
post #10 of 14 (permalink) Old 05-20-2010, 12:34 AM Thread Starter
Big_Rubber's Avatar
F*ck... Guy told me it worked perfect with his 2" coil spacers wasted 115$ on this friggin thing. I had the carli bar on for like a month but returned it cause truck still had DW and they told me that it was another fix and did absolutely nothing for me so I returned it but since then I fixed all the DW issues and thought a track bar would be a good addition to recenter my diff.
Well can I buy the track bar drop bracket and just shorten the sh1t out of the track bar?
post #11 of 14 (permalink) Old 05-20-2010, 05:19 PM
Jeepstang's Avatar
I suggest that you give Jeremy a call over a Rock Krawler
he is the owner and very knowledgeable. He is a nice guy to work with
518-270-0822
2014 Ram 2500 crew cab limited
Jeepstang is offline
post #12 of 14 (permalink) Old 05-20-2010, 07:52 PM Thread Starter
Big_Rubber's Avatar
518-270-0822
Thanks for the number, luckily enough my dad has an 07 with a 6" lift so he is just gonna buy it off me what I paid and I'm gonna order another Carli or Kore track bar that actually works with a 3" kit from George.
Thanks for the help guys
