Lumbar support broke...help - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 17 (permalink) Old 08-19-2009, 09:09 PM Thread Starter
SHINER1836's Avatar
Anyone know where to get lumbar support pieces for the front drivers seat? the damn lumbar support broke today when I hit a bump....quality stuff.....where can i find a part for that?
2008 2500 6.7l 4dr, longbed, 4x4 SLT, Custom STO steel. H&S XRT 175, H&S 5" Turbo Back, S&B Intake, EGR Blocked, Dipricol Guages, SBC DD 3250, BFG 315/70/17
SHINER1836 is offline
post #2 of 17 (permalink) Old 08-19-2009, 09:11 PM
seanth468's Avatar
iTrader Score: 5 reviews
I thought the seats came with a 5 year warranty
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Anarchy,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Toyo AT2's.
seanth468 is offline
post #3 of 17 (permalink) Old 08-19-2009, 09:34 PM Thread Starter
SHINER1836's Avatar
ya i dont know....its possible....i took the seat apart earlier and can fix it pretty quick as long as i can get the part
post #4 of 17 (permalink) Old 08-20-2009, 09:01 AM
Mine broke as well (turned the knob too hard). It was covered by warranty and fixed by the dealer. I believe they had the part in inventory.
07.5 2500 QC 4x4 Laramie, Mineral Gray, 3.73 diff, 6" Superlift and 3" body lift, 38" Toyo M/T, 18" Cepek Rims, BaKflip folding tonneau cover, MOPAR step tubes, spray-in liner, EGR unplugged.
dkm2 is offline
post #5 of 17 (permalink) Old 08-21-2009, 07:45 PM
Si vis pacem, para bellum
BroncoHound's Avatar
If you don't have a warranty left (it just falls under the 3yr/36k mile), the dealer will try to sell you the entire seat back at the tune of $400. They will tell you that they can't get the lumbar strip by itself. This is wrong. The part number for the replacement lumbar strip is is1-05166079aa. Hope this helps.
Kort: '08 QCSB 4WD CTD G56 4.10: H&S | Draconian | ISSPRO | PureFlow | GDP | South Bend | Carli | DT ProFab | King | Toyo | Method | Softopper
Jolene: '13 JKR NSG370 4.10: Edelbrock | Diablo | Bartact | sPOD | RK | Teraflex | AEV | Fox | Adams | SteerSmarts | Duratrac | General | Method | JCR | Warn | KC
Virginia: '16 Challenger Hellcat TR6060: Speedlogix | BT
BroncoHound is offline
post #6 of 17 (permalink) Old 08-23-2009, 11:43 PM Thread Starter
SHINER1836's Avatar
awesome! thanks for the help guys! ill see what they try and slide by me this week!
post #7 of 17 (permalink) Old 08-24-2009, 12:16 PM
Is this the part number for the manual lumbar? I bought a front seat to replace my torn and foam crumbling drivers seat....how difficult would it be to put my power lumbar back on the seat I just bought w/ manual lumbar?.....as for fixing the manual lumbar, the knob just spins easily , what needs replacing to fix this?
03-2500 Flame Red QC SB 4X4 HO SLT 48RE-Alpine-stock alum rims wrapped w/ 285/75 Nitto Duras-Rotella and Wix- looking to add Edge or Smarty....87 Furd F250 4x2 6.9 NATURAL..
HIGHRISK is offline
post #8 of 17 (permalink) Old 08-24-2009, 12:59 PM
Yes, it's for the manual lumbar. I have no idea how involved converting manual to power would be, but i would imagine it couldn't be THAT complicated. Why couldn't you just transfer the cushions and seat covers from the replacement seat to your existing frame with power lumbar?
As for fixing the manual lumbar, free spinning adjustment wheel probably means the little white plastic housing of the retention pin is busted; terrible design flaw to make the housing plastic since it bears all the twisting forces when turning the knob if you ask me. When the one in my father's '05 broke, I ended up replacing the manual lumbar assembly which is the part number i referenced earlier. Over on DTR just yesterday, however, a new member posted a $0.99 fix that reads like it might just do the trick and make the lumbar much less prone to failure again down the road. Here is a copy of his post:
Originally Posted by RichGuider on DTR
It looks like it's been over a year since someone has updated this thread, so i'll go ahead and add my two cents for a quick $0.99 cent repair to probably the most frequent issue for breaking manual lumbar supports.
I hopped up into my 2005 Dodge Ram last night and felt my manual lumbar support give way. The problem was that the white plastic spinner inside the black housing broke at the point where it surrounds the tension pin (you'll understand exactly where all these points are once you see them).
I did an online search for repair and the best option i found was to hand over $40.00 for a new lumbar mechanism. My wife is a checkbook Nazi so i knew i was on a tight budget -- which most times forces creativity.
This problem can be fixed simply with an eye bolt and nut... more specifically: a $0.99 pack from Home Depot: #8-32 x 1-5/8" eye bolt.
Basically, for those that already know more than i did about the mechanism, all you're doing is creating a new hole for the tension pin with the eye bolt.
If you're not much of a fix-it guru (i'm certainly not), don't be shy when disassembling the lumbar mechanism because it's not a difficult fix. Here's how i did it on my 2005 Ram (and i don't know technical jargon, so forgive the simple language):
-Remove the adjustment knob. Mine just pulled off.
-Remove the black trim under the knob (2 screws).
-Carefully remove the white housing (2 screws; this will be under the seat fabric, so carefully remove).
-Twist the white, plastic tension screw. This is actually a two-piece mechanism. If it twists freely until it comes out, then you've found your problem; you'll see the end of this plastic hardware broken and missing half the housing that surrounds the tension pin.
-HERE'S WHERE YOU USE THE EYE BOLT: Unscrew the two white plastic screws. In the middle of the groove where the tension pin rests, drill a hole (large enough for the bolt) straight through the broken plastic screw. Insert the eye bolt until the eye portion rests along the groove in the screw. Place and tighten the nut on the other end of the eye bolt that's protruding from the end of the plastic screw. Reconnect the two plastic screws.
-Tilt the seat as far forward as you can. Under the back portion of the seat you'll find an access point to the seat guts. Carefully pull the the locking strip apart and fold the fabric up until you can clearly see the lumbar mechanism on the backside.
-From the side of the seat where you've removed the adjustment mechanism, push the release tab and twist the black cylindrical mechanism so that you now can access this part from the back of the seat.
-Push the tension pin out of one side of the lumbar strap and fully out of the black housing.
-Insert the plastic screw mechanism with new eye bolt into the black housing (eye bolt first)... you see where i'm headed with this now, don't you?
-Push the tension pin back through the black housing, MAKING SURE IT FINDS ITS WAY THROUGH ITS NEW, METAL RIGID HOME, and back through the lumbar strap.
-Push and twist the black mechanism back into the seat housing.
-Fold the seat fabric down and reconnect strips.
-Replace white housing, making sure to carefully push it under the fabric.
-Replace black trim.
-Replace knob.
-Enjoy a beer (or two) and give your wife some flowers with the money you've saved.
Here is the link to the original post on DTR: http://www.dieseltruckresource.com/d...t-t198615.html
The Following 5 Users Say Thank You to BroncoHound For This Useful Post:
deankats (08-10-2013), jamesr (07-04-2011), montara24d (05-25-2015), UNDER-PRESSURE (12-02-2011), white.lightnin' (07-07-2011)
post #9 of 17 (permalink) Old 08-24-2009, 01:25 PM
that does make the most sense.....transfer the lower seat cushion and cover...I could add the memory foam base mod at that time....still want to fix the manual lumbar....thanks for the directions....this place beats TDR hands down....TDR is over rated......
HIGHRISK is offline
post #10 of 17 (permalink) Old 12-03-2010, 01:59 PM
Here is the link to the original post on DTR: http://www.truckresource.com/dev/dri...t-t198615.html
I just tried that fix with an eye bolt.....easy and a permanent fix, no way it can break now an 100 times stronger than the stock POS. only took a couple hours and less than $2.00 at a hrdware store.
My back thanks you for that link.
2002 Ram 2500 4x4 2nd generation 24v Cummins 6 speed 4" Lift on 35"s Quad Cab Short bed
cj5andy is offline
post #11 of 17 (permalink) Old 12-01-2011, 01:29 PM
This quick fix works, I just did mine yesterday. $0.33 part, less than 30 min and I now have my lumbar back. There is a post that has pictures of the assembly but the link shown above gives you the information needed to do this little fix. I found that the eye bolt nut was a little too big to allow the plastic screw to move to its fullest position so I simply ground down the nut on the eye bolt until it seated to my satisfaction. Sure glad to find such a cheap fix that is likely 100% better than the factory part that keeps breaking.
mikebollinger is offline
post #12 of 17 (permalink) Old 03-16-2012, 07:45 AM
I did the eye bolt repair, but I wrapped a washcloth around the lumbar band to increase the amount of lumbar support. Much more comfy.
2009 2500 4X4 Auto Quad Shortbed Bighorn, Insight, Unplugged EGR, Cardboard tree air freshener.
Hickey is offline
