How to Remove the Headlight assembly. - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 12 (permalink) Old 01-09-2009, 07:23 PM Thread Starter
higgs's Avatar
Can someone help me out. I just received my hid's tonight and I can not remove the headlight assembly. I removed the 2 bolts in the front and remove 1 nut under the wheel well. The light does not want to come out. Is the another bolt or nut I am missing? Any help will be appreciated..
2008 Dodge Ram 2500 QC 4X4 6.7L Big Horn Edition. AirRaid Intake, MP-8, 5in. MagnaFlow, Quadzilla boost fooler, SmartyS67
higgs is offline
post #2 of 12 (permalink) Old 01-09-2009, 07:27 PM
Retired Engineer
Courierdog's Avatar
No you have removed two bolts in the front and the one nut in the rear.
The trick now is to pull hard to overcome the plastic guide pin with the retaining clip.
The guide pin looks like a ball bearing on the end of a rod with a four fingered clip holding the plastic ball bearing in place. It is a real pain especially if you have to change out a head lamp on the side of the road in the middle of winter at night at -40C
2007 6.7 L, 2500 QC, Laramie, SB, 3.42, Mag-Hytec, 68RFE, Harvard 750 Bypass Oil Filter, Patriot Blue, 4X2, Michelin LTX Summer, Michelin X Winter, Raider Canopy, HERD Bumper, Espar Cab Heater, Sirius, Smarty 25ME, SS636, WCC Intake Manifold & 3.5 inch Boost Tube, Donaldson 100580, PMT Gauge Set, Smarty, Optima Red Top Batteries, Have Truck, Will Travel
Courierdog is offline
The Following User Says Thank You to Courierdog For This Useful Post:
4 door fury (12-15-2010)
post #3 of 12 (permalink) Old 01-09-2009, 07:30 PM
there are the 2 bolts up front the one in the wheel well! and then there is a ball that pops in a holder that acts as a swivel! u have to pull pretty hard to pop it out! and then u have to push pretty hard to pop it back in! its just above the wheel well bolt but u can see it at all!
2012 3500 2wd G56 crew, long bed, dually, MM, mp8, bd boost fooler, s&b, 5" ss turbo back, deletes, H&S intake horn, H&S boost tubes
2004.5, 4x4 5.9 4dr short bed, hummers, 35's
1983 toyota truggy 22R 225hp on propane,hydro,linked,38's
Exoyota is offline
The Following User Says Thank You to Exoyota For This Useful Post:
post #4 of 12 (permalink) Old 01-09-2009, 07:31 PM
i know how u feel courier!! it is a pain in the !!!!!!! hahaha
Exoyota is offline
post #5 of 12 (permalink) Old 01-09-2009, 07:42 PM
04SSHD's Avatar
3 bolts and pull REALLY, REALLY HARD. That's about the only trick there is.
04 Ford F250 CCSB FX4 6.0 Powerstroke, 9" Skyjacker, 38" Toyo's, AMP Steps, Bulletproofing in process
07.5 Dodge Ram 3500HD SLT 6.7L (SOLD)
04SSHD is offline
post #6 of 12 (permalink) Old 01-09-2009, 08:03 PM
clark4131's Avatar
Do yourself a favor and put a cover of some sort over the bumper just under the headlight. When the thing pops out, it comes out with some force and you can scratch the poop out of the paint. I just did it two days ago and it takes a surprising amount of force with no reall good grip points...SC
'08 2500 Mega SXT, Smarty 6.7ME, MHP TCM, EDGE Insight, AirDog II-165, BMK-21, S&B Intake, GDP Intake Horn/TV Delete/Fuel Filter Delete, Bilstein 5100's, HBS Level Kit, EGR MIA, Stealth DPF/NOx, Mag-Hytec Tranny & Rear Diff Pans, Carli Trackbar, DSS Steering Brace, RCX Dual Bilstein Stabilizers, Detroit TrueTrac, Fusion Front/Fab Fours Rear Bumpers ...
clark4131 is offline
post #7 of 12 (permalink) Old 01-09-2009, 08:14 PM
Black_Ram07's Avatar
Oh man you have no clue how happy I am that someone else asked this question first!!! I've been dreading turning my headlights on for fear of one being burnt out! lol
2007 Bighorn 5.9, 5" from downpipe to 5" stacks, Edge EZ, BD boost fooler (long gone
) 2011 bighorn 6.7 bone stock (HATED AND SOLD) 77 chevy 2wd cc dually cummins... <---- ok maybe not but almost what I have.
Black_Ram07 is offline
post #8 of 12 (permalink) Old 08-24-2012, 03:59 AM
Adriasn15's Avatar
This is old but this helped me from getting a ticket on the long drive home!
2008 Mega Cab 4x4 auto Resistol Edition - mini max, leveling kit, 5in TBE, 37/12.5/17 trail grapplers.
Adriasn15 is offline
post #9 of 12 (permalink) Old 03-27-2015, 11:26 PM
walterjn's Avatar
Has anybody tried grease on that little pivot ball?
walterjn is offline
post #10 of 12 (permalink) Old 03-27-2015, 11:32 PM
drtnsnw's Avatar
Won't really do much good, it is meant to be tight. The mirrors on my BMW MC have the same kind of ball and socket and to take them off you WHACK the mirror with the palm of your hand like you are trying to break it and it pops off!! Freaks you out the first time!!
Chris
Juice/ Attitude for sale
drtnsnw is offline
post #11 of 12 (permalink) Old 06-30-2015, 05:00 PM
Harried Harry's Avatar
I've been trying to figure this out for weeks. I wish someone would make a short video. I'm not very good with video cameras since mine is VHS format. Thanks for the suggestions.
Harried Harry is offline
post #12 of 12 (permalink) Old 06-30-2015, 07:23 PM
I've pulled housing off my 07 many times here are a few simple tricks that I use.
1) Wear leather or mechanics gloves they provide better grip
2) Try to get you finger tips just under the lip of the housing of the middle of the housing on the fender
3) Then with your left hand on the fender side of the housing (with finger or tow under the lip) and your right hand pulling back on the inside housing where the grill where the 2 bolts are.
4) Pull straight back, not up not down, but straight back, hard a few times if necessary and it will pop out.
coder is offline
