Check Engine Light? - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 9 (permalink) Old 07-16-2010, 05:05 PM Thread Starter
Check Engine Light?
I installed an AFE #75-31342 Proguard & airbox on Wednesday evening, drove the truck for about 100-150 miles and this morning (Friday) while cruising up the highway the dreaded check engine light came on. Didn't check the code, but I'm sure it's air intake related.
The question is, what can I do to keep this from happening? Is a tune needed? How can I check codes (something with the key switch?) And lastly, how to clear the code? Thanks in advance.
'05 Dodge Ram 2500 4WD Diesel, '10 Dodge Ram 3500 Chassis Cab w/utility body.
SCRUB is offline
post #2 of 9 (permalink) Old 07-16-2010, 05:09 PM
blacksmoke101's Avatar
if this is on your C&C i bet you have the code i had, i dont have a C&C but i put a S&B on and got something like air intake to high or something to that extent, Mine also had a boost fooler on it at the time. But with a tuner ive yet to see it again, and being deleted as well. Maybe the mods will move this to the right section and help you out.
ps to check for codes... key in go on off on off on and it will display codes where the miles are shown
2013 Laramie leveled tinted and PPEI tuned
blacksmoke101 is offline
post #3 of 9 (permalink) Old 07-16-2010, 05:22 PM Thread Starter
Thanks, what section should this be posted in? Yes, it's on my 2010 chassis cab.
SCRUB is offline
post #4 of 9 (permalink) Old 07-16-2010, 05:24 PM
tough call... Maybe the C&C section right below this one or the 2010 section
post #5 of 9 (permalink) Old 07-17-2010, 06:24 PM
CTD&TDI's Avatar
from the research I did when looking for a cai, the only company I came acrossed that didnt have c/c issues was s&b. I like afe alot, but went with the s&b because the afe specifically said it would cause a CEL on the c/c
2014 3500 CTD CC Laramie, 385/850, Aisin, 4x4, 4.10, 28k and climbing, STAYING STOCK
2007 3500 C&C, 6.7 CTD, Aisin, 4.10, 4x4, Black, Reg cab, 270k, 7520 hours, TRADED
2004 3500, 5.9 CTD, 6 spd, 3.73, 4x2, Black, Quad cab, 270k, 8268 hours, DiPricol Optix FP, EGT, Boost, AFE Bladerunner IC, Cowl Hood, Airdog FP100, GDP Canister Delete
1995 3500, 5.9 CTD, 5 spd, 4x2, Black, Reg Cab, Laramie, 121k, 4" TBE from RSD, Isspro EV's 60 FP, 60 Boost, Pyro going in next...
CTD&TDI is offline
post #6 of 9 (permalink) Old 07-17-2010, 06:24 PM
CTD&TDI's Avatar
oh and the s&b was cheaper
CTD&TDI is offline
post #7 of 9 (permalink) Old 07-18-2010, 01:28 PM Thread Starter
I don't mind the light, but I'm questioning whether or not the system will richen up the mix like a gasoline car does when the 02 sensor reads a lean a/f ratio. I do plan on a dpf delete/exhaust mod and tune after the warranty is up. I guess I could tune it out. Thoughts?
SCRUB is offline
post #8 of 9 (permalink) Old 07-19-2010, 06:16 PM Thread Starter
So, how do you clear a CEL on these systems?
SCRUB is offline
post #9 of 9 (permalink) Old 07-21-2010, 06:11 PM Thread Starter
Well, the light went out after a few driving cycles and hasn't come back on in 2 days/250 miles. Maybe I'll get lucky.
SCRUB is offline
