Headlight Fuse, Where is it? - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 13 (permalink) Old 02-03-2010, 09:31 PM Thread Starter
LaFrance454's Avatar
Anybody tell me where the headlight fuse is. I was under the impression our trucks only had one fuse box under the hood and I dont see anything for headlight
07.5 6.7 G56 C&C. With some goodies
LaFrance454 is offline
post #2 of 13 (permalink) Old 02-07-2010, 06:14 PM Thread Starter
bump for help?
post #3 of 13 (permalink) Old 02-07-2010, 06:30 PM
seanth468's Avatar
iTrader Score: 5 reviews
I just looked and can't find one designated for the headlamps either, sorry
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Anarchy,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Toyo AT2's.
seanth468 is offline
post #4 of 13 (permalink) Old 02-07-2010, 06:42 PM
seanth468's Avatar
One thing you could try would be take a test light and test all the fuses listed for the other lights. Turn your light switch on while doing this.
post #5 of 13 (permalink) Old 02-07-2010, 06:59 PM
Hi
No headlamp fuse. Headlamps controlled by TIPM (Totally Intergrated Power Module). A VERRRRy fussy critter. If plow lights or other accessories not added correctly, pop goes the tipm. Sometimes it can be reset/rebooted.
Charlie
RegenerationCompleted is offline
The Following User Says Thank You to RegenerationCompleted For This Useful Post:
seanth468 (02-07-2010)
post #6 of 13 (permalink) Old 02-08-2010, 03:55 PM
04SSHD's Avatar
There's a fuse for them, I've had to replace one of mine before. There are actually two fuses, one for right side and one for left side and they are both under the hood
04 Ford F250 CCSB FX4 6.0 Powerstroke, 9" Skyjacker, 38" Toyo's, AMP Steps, Bulletproofing in process
07.5 Dodge Ram 3500HD SLT 6.7L (SOLD)
04SSHD is offline
post #7 of 13 (permalink) Old 02-08-2010, 09:37 PM Thread Starter
i cant find one under my hood. and my tipm fuse is #17 in my fuse block and its listed as a spare. I cannt find any headlamp fuses...I have no lowbeam power to my plug on the passenger side.
post #8 of 13 (permalink) Old 02-09-2010, 07:43 AM
04SSHD's Avatar
you are correct, I just ran out and checked. I was mistaken for the turn signal fuses which I had to change awhile back.
04SSHD is offline
post #9 of 13 (permalink) Old 02-09-2010, 07:32 PM Thread Starter
so there is no headlamp fuse?
post #10 of 13 (permalink) Old 02-18-2010, 10:29 PM
i know before my TIPM completely took a dump(both times) i was having problems with the lights. Might want to go get it checked out at the stealership.
Hope that's not your problem, but just giving you an idea
'13 4500 CC 4x4 197"WB, stock.
Goat08 is offline
post #11 of 13 (permalink) Old 02-28-2010, 01:47 PM Thread Starter
alright thanks alot, I have power to my headlamp plugs just not the lowbeam on the driver side. Could the TIPM control that? Also, I have a lot of chicken lights on the truck and there all tied into the running lights. Would that have somethin to do with it
post #12 of 13 (permalink) Old 03-01-2010, 11:16 AM
I know both times my TIPM fried the lights started doing weird things. Low beam on one side didnt work, then they both didnt and then they did, then my running lights went out. This past time I had it fixed they went through and cleaned all my grounds and told me to do the same on my trailer.
I know when the bed was put on we had to have the dealer turn up the juice for the lights to work properly. I would seriously get them to hook up to your truck and see if something shorted that circuit out.
Goat08 is offline
The Following User Says Thank You to Goat08 For This Useful Post:
eodguy (06-23-2014)
