Fuel filter change? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7 Liter General Discussion
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
Old 11-13-2008, 09:28 PM   #1 (permalink)
susee80's Avatar
Fuel filter change?
Stupid noobie question but I have never done it so here goes. I need to change the fuel filter in my truck how is it done? (You can stop laughing already)TIA
2007 6.7, AT, 2" HBS, 35" Pro Comp M/T,Welds, S&B CAI, ride rite, line-x, husky liners, mopar steps,dvd, 12" kicker, cheap fogzilla, ATS fender flares, vertical billet grille, Smarty Jr, Insight, Remote Start, Leer XQ, deletes SOLD!!
susee80 is offline   Reply With Quote
Old 11-13-2008, 09:46 PM   #2 (permalink)
trlr prk's Avatar
iTrader Score: 4 reviews
Look a few pages back in the 6.7 powertrain section, there are a couple sets of step by step instructions.
08. 2500. QCLB. 4x4. 68RFE. Mini Maxx. Full Deletes.
trlr prk is offline   Reply With Quote
Old 11-13-2008, 10:06 PM   #3 (permalink)
GreenDieselPower's Avatar
Well first Cummins really made this process easy
I do not know any easy way of doing it besides going under truck and have a quart of diesel poor all over you.
Step One Turn Truck off and let cool
Step Two open the white valve on the filter to drain the fuel out of it. Some say key on the truck to get the fuel to drain out faster.
Step Three Once filter seems to be empty use a 1/2" drive Ratchet with a swivel extension to remove it. You will see there is slot in the bottom center that the extension grips the filter. Spin filter off. Beware of it spilling fuel all over you
Step three pull the filter through the top of the engine between the battery and the master cylinder. ( It won't be easy. )
Step Four Take the new filter and install the red O-Ring on the new filter. Then make sure the rubber gasket is installed on the tip of the fuel filter.
Step Five Re-Install fuel filter hand tight only. You can not use the 1/2" Ratchet.
Step Six Key on the truck and tap the starter and wait 20 - 30 seconds. Do this 3-5 times.
Step Seven Crank the Truck it sometime will give you a hard time to start but it will start after 3-4 times. Truck will run and then cut out. Start it again and then you should be good to go.
Step Eight Turn Truck of and start
Good luck..
When you get tired of doing this process I would Recommend a Racor Filter 2 Microns Here is a Pic
http://www.freeimagehosting.net/uploads/f3705953a8.jpg
2007 Ram 3500 6.7 H&S EGR & DPF Delete, FASS Lift Pump, Stock Fuel filter Delete , Racor 900 2 Micron, EGR Cooler delete 80hp Sticks, 5" Silverline Stacks & ?
6.7 =
GreenDieselPower is offline   Reply With Quote
Old 11-13-2008, 10:18 PM   #4 (permalink)
black06cumminz's Avatar
watch out for the 2 step 3' s
Robbie Stumbo,07.5 dodge 2500 mega 4x4, Bod 80hp nozzles, stage 3.5 pump, htt 64 with s480, mp8, ats trans with copilot, WCC intake, arp 625 studs and EFI and tcm tuned by Dave Mathews 759 hp and 1358 tq.
black06cumminz is offline   Reply With Quote
Old 11-13-2008, 10:23 PM   #5 (permalink)
dont forget to unplug the wire connector.....it is not an easy job...turn the wheel all the way to the right before you start...it is a whole lot easier to get the filter out through the fender then the top. you can use a filter wrench through there as well to get it loose...they are tighter than tight from the factory.
08 laramie mega cab 6.7 some goodies. 07.5 laramie quad cab some things fell off
torquey is offline   Reply With Quote
Old 11-13-2008, 10:53 PM   #6 (permalink)
susee80's Avatar
Thanks for the help. I will be doing it this weekend. Do you guys recommend a filter from the stealership or is there a good aftermarket one? Sounds like maybe I should get a poncho or rain suit I am used to JP-8 and Hydro fluid so hopefully it won't bother me to much. Thanks again!
Old 11-13-2008, 11:01 PM   #7 (permalink)
RATLIN'HP's Avatar
dealer filters are way cheaper than most aftermarket, and just as good as most. there is also some steps left out of the instructions. in between about every other step listed above is the step where you have to go get some bandaids, and clean the fuel out of your bleeding knuckles.
2008 Mega Dually 3500. GONE
2012 Mega Dually. All the options, minus the soot cooker. H&S Mini, OD Trans Tune.
RATLIN'HP is offline   Reply With Quote
Old 11-14-2008, 06:55 AM   #8 (permalink)
MisterScott's Avatar
Really makes me want to do this myself....
2011 Megacab 4X4 3500 Laramie
MisterScott is offline   Reply With Quote
Old 11-14-2008, 07:49 AM   #9 (permalink)
cntryby's Avatar
Holy poopie...I was gonna post a link to where I got my filter at...Geno's garage, for $13.95. When I went to get the link, they are now $27.95.
Glad I bought 3. :thumbsup
Filters - Fuel-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage
I'll have ta do some more shopping now. The stealers wanted $70 something for theirs...what joke.
Oh yeah, the fleetguard at Geno's is $25.
08, 3500, mega, 4X4, Passenger Industries manifold & tube, sub-zero intercooler, Flo-pro 5" SS TBE, Hot Damn 175 ATT, ARP 2000's, Nitto Terra Grapplers, SRT hood, Amp power steps, B&W turnover & Tow n Stow, line-xtra, limo tint... great big nuts.
cntryby is offline   Reply With Quote
Old 11-14-2008, 09:35 AM   #10 (permalink)
wildcat05's Avatar
Don't forget the case of beer, in between the bloody knuckles
07' 2500 MC, 4X4, 6.7, Auto, SLT, XRT, 5" TBE, H&S EGR and Cooler delete, S&B intake, Isspro EV2's
01' 2500 QC, 4X4, 5.9, Auto, Sport, BHAF, No silencer Ring, 4" Straight, MagHytec
wildcat05 is offline   Reply With Quote
Old 11-14-2008, 10:00 AM   #11 (permalink)
spoolin'up's Avatar
LOL, I just did mine the other day, and you're right about everything except the band-aids... the diesel fuel will cauterize the wounds.
As far as removal goes, I did mine from under the truck. You can unscrew it with your right hand, then reach your left arm up through the space right next to the firewall and you can remove the filter through there. When re-installing, put a rag over the top of the filter as you push it back up through that hole to keep dirt from the firewall and hoses from getting in the filter.
2007.5 3500 Laramie MegaCab 4x4 SRW 68RFE
spoolin'up is offline   Reply With Quote
Old 11-14-2008, 10:02 AM   #12 (permalink)
tr200's Avatar
drain filter
If you open drain valve on bottom of filter, attach 3' length of hose. Put hose end in drain pan. Then loosen filter until fuel drians out the hose. Then you can remove filter no mess at all. I learned this the hard way. Just losening the drian valve on bottom does nothing without losening the filter.
2013 Tradesman 6 speed auto, Kelly Safari TSR 285/70/17, XD Spy wheels
tr200 is offline   Reply With Quote
