Radiator Fan Removal - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 8 (permalink) Old 10-30-2008, 08:14 PM Thread Starter
txag09's Avatar
I am trying to remove my radiator fan to replace it with an electric fan but am having a difficult time removing the fan and clutch assembly. Does any one know how to remove this, and give me some kind of instructions?
Thanks in advance for any help
MINE 2007.5 dually somewhat stock
HERS 2001 2WD 2500 auto... it has a grid heater delete
txag09 is offline
post #2 of 8 (permalink) Old 10-31-2008, 08:25 PM
Cigar101's Avatar
I used a air chisel on the nut
Cigar101 is offline
post #3 of 8 (permalink) Old 11-01-2008, 05:48 PM
Cigar101 - Can you give us more info on whats invloved? Was the nut super tight? I don't have a 36mm wrench. Would a flat wrench or a socket work best. Is it a right hand thread?
Thanks.
2008 Dodge 3500 SRW QC LB 4x4, Auto, 3.73, 6.7L. Thuren springs. Thuren TB, HID's. All deletes. Smarty. 4040XL. Banks SuperScoop. RockCrusher diff guards. Defiant steering support & stone shield. Goerend TC. WCC intake & boost tube. No grid heater. King 2.5" shocks, Carli CA, Yokohama 37", Flex-a-lite fan, Carli Sway bar, Sulastic shackles, MHP trans tune, 3 - Hella 4000's w/55W HID's on Defiant bar.
milo12 is offline
post #4 of 8 (permalink) Old 11-02-2008, 08:06 AM
Cigar101's Avatar
My fan and clutch were broken by a stick that floated in between the fan shroud and the fan,the dealer wanted 600.00 for the repair, I found this article and did ude a air chisel to crack the nut in 2.
www truckinweb.com and in the search box type in "electric horsepower"
Cigar101 is offline
post #5 of 8 (permalink) Old 11-02-2008, 08:41 AM
Feelings NOT Included!
cumminalong's Avatar
You need a fan clutch wrench, otherwise it's a bastard.
Off hand, it's like a 37mm or something like that.
Go to any one of the auto parts stores, they have them.
Don't buy the Dodge tool, it's like $100+
You can get the exact same tool for about $12.
- Garmon Stage 4 Fat Shaft, Trips (FMW 472 over a pair of FMW 467's)
- Garmon High Pressure 68RFE
Shut up and open your wallet! This whoopin' ain't gonna be free!
cumminalong is offline
post #6 of 8 (permalink) Old 11-02-2008, 08:44 AM
BILLS06's Avatar
Threads are right hand and you need to borrow or buy a fan clutch tool. Nothing more than a real flat wrench. If you buy one, run a couple beads so it doesn't spread open. Also need to remove the shroud with it. Going to be a man job.
06 QCSB SLT
Headlight Eyelids Fluidampr EZ Down ATS Converter Fog Lamps Aero Turbine Muffler Reflex Bed Liner
[SIGPIC][/SIGPIC]
BILLS06 is offline
post #7 of 8 (permalink) Old 11-02-2008, 12:43 PM
PuFF~PuFF's Avatar
hey man u should do a write up and pics as u do it to help other ppl out. :thumbsup
PuFF~PuFF is offline
post #8 of 8 (permalink) Old 11-02-2008, 04:53 PM
I found this.
Schley Products (SP 61200) 2 Pc. Universal Fan Clutch Wrench Set - SP 61200
One tool is to hold the clutch from spinning and the other is the wrench.
Is it worth the money?
milo12 is offline
