oil change ......... - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 10 (permalink) Old 07-31-2012, 08:26 AM Thread Starter
Hi,
My 2012 Dodge Ram 2500 with the 6.7L Cummins Diesel engine will soon be due for it's first oil change. Is it recommended to use conventional motor oil or full synthetic motor oil? Also, I know what the owner's manual recommends regarding oil weight, but are there different/better recommendations regarding oil weight?
Thanks,
Jim
jbach is offline
post #2 of 10 (permalink) Old 07-31-2012, 08:56 AM
Weight according to your climate. The recommended weight takes care of most climate types, but if youre in miami you probably dont need to do the colder stuff
Synthetic or conventional is personal preference and your ability to pay the extra money synthetic costs. Im not sure at this point which one I will use
oaklandopen is offline
post #3 of 10 (permalink) Old 07-31-2012, 09:50 AM
Wandell's Avatar
I always ran synthetic in my gas engines for the added protection and extended oil change intervals (6000 is what I did). But since cummins recommends 7500 intervals, I may use conventional oil and change it every 6000 or 7000 miles. What do you guys do?
White 2012 Ram 2500 ST Crewcab, AT, 3.73s, Rough Country 5 inch lift, 22x12 Fuel Mavericks, 35x12.50 Toyo MT's, H&S XRT Pro programmer, MBRP exhaust
Wandell is offline
post #4 of 10 (permalink) Old 07-31-2012, 12:52 PM
Diesel Filled Veins!
Sandman76's Avatar
- Bob is the Oil Guy is a huge source of information on oil and after reading a ton on there you can make an informed decision what oil is best for you.
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #5 of 10 (permalink) Old 07-31-2012, 01:22 PM
Before I was deleted my Ram wanted an oil change (according to the EVIC) every 2,000 miles due to the frequent regens. The oil was filthy too. I'm not sure synthetic makes much sense if you're changing that often. If you can get the 7,500 between changes it might.
2012 RAM 3500 Laramie 4x4 G56 3.73 SB3250 Carli Pintop/Sway bar/Track bar/Full leafs 295/70/18s on Hostages, 35w Retroshop HID Projectors and fogs, a bunch of other stuff, oh and some other stuff fell off.
Ram2012 is offline
post #6 of 10 (permalink) Old 07-31-2012, 02:31 PM
I switched to Rotella T6 Synthetic 5w-40 at around 10k miles.
I also use a Donaldson ELF7349 so now I can extend the drain intervals to 10-15k. YMMV.
2008 Brilliant Black 3500 QC Laramie 4x4 | 285/70/17 Toyo AT2's | Anarchy EFI Live | DPF Delete | HBS Steering Brace | Thuren 2" Soft-Ride Coils | Thuren Overland Shocks | Thuren Track Bar | Sulastic Shackles
radjxf is offline
post #7 of 10 (permalink) Old 08-02-2012, 09:56 PM
VP Moderator
dozer12216's Avatar
Due to the fuel contamination that occurs and The EXTREME variations in use, my suggestion is: Use convential oil as fuel will dilute syn oil just as quickly. change it based on the oil change indicator as it keeps track of the variables that occur.
one may need change at 3000 miles due to fuel dilution and number of regens required. Another may need change at 6000 miles. On my unit the message arrived at near 8000 miles. For these shorter change intervals, it is hard to justify the added cost of synthetic. On my 2000, I changed at up to 17500 miles and used syn oil with EOA perfromed appropiatelly.
dozer12216 is offline
post #8 of 10 (permalink) Old 08-02-2012, 11:11 PM
countrycummins30's Avatar
Is anyone just running a delo 400? Its all I put in my 04 I get it for free from my work so was hoping I could put it in my 2012 bighorn
Sent from my DROID RAZR using AutoGuide.Com Free App
12 3500 srw 3" back country, amp power steps, 35x12.50x18" trail grapplers, diamond eye 5", hs egr delete, mini max, dd south bend, tinted, 2 10" kickers Rockford amp
countrycummins30 is offline
post #9 of 10 (permalink) Old 08-02-2012, 11:28 PM
Delmar's Avatar
You can start running synthetic after your first oil change.
I started running Rotella T6 at about 50,000 miles. According to my last UOA from Blackstone Labs they stated everything looks good & to take a sample at 15,000 miles this time.
My truck is deleted, running the H&S XRT PRO on "No Power" & grossing 22,000 LBS - 34,XXX LBS almost daily. No oil bypass filter as of yet. I may order one in the next couple weeks.
2011 3500 C/C DRW 6X6 G56 All of the EPA stuff fell off Tuned by H&S Valair Dual Disc Organic Clutch
Delmar is offline
post #10 of 10 (permalink) Old 08-02-2012, 11:32 PM
OilFun's Avatar
I agree, when the truck goes into regeneration mode (dpf equipped) it causes fuel dilution there are several threads on here (why is my truck making oil) if u want to research.
After putting synthetic oil in my brand new hemi many moons ago at only ~500 miles it slowly burnt about 1.5qts an oil change at 5k a change. After that I've learned to wait for an engine to break in before adding slippery oils (full synthetics). I've read on this forum to wait 20k-30k miles.
'09 2500 Laramie Mega G56 (retired)
'15 2500 Limited Mega 68RFE
OilFun is offline
