Maintence Schedule request - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 10 (permalink) Old 04-12-2012, 12:11 AM Thread Starter
armymech's Avatar
Hey fellow cummin owners,
I'm sure yall are gonna say "search for it" or "google it"
But i count not seem to find a well layed out and POL type schedule.
I have a pretty good general idea since i work on military trucks, But since this is my first cummins, i want a 6.7 schedule that will keep me on the right path to have this truck forever. If you dont have any positive input just observe then. Dont need your .02 Thanks!
2006 Dodge Ram 3500 5.9l SRW Mega Cab 4x4 EFI by PPEI - Trans by Firepunk - 4in TBE
2001 Dodge Ram 2500 5.9l QCSB 4x4 SOLD
2007.5 Dodge Ram 2500 6.7l Mega Cab 4x4 SOLD
armymech is offline
post #2 of 10 (permalink) Old 04-12-2012, 12:38 AM
Using good oil ordered in the mail, or crap oil off the shelf at the store?
Plan on installing an oil bypass filter?
Do the instructions need to be Army proof?
2006 3500 MegaPig | Carli Trussed 6" Long Travel Dominator
ant.foste is offline
post #3 of 10 (permalink) Old 04-12-2012, 01:46 AM
DenverDodgeDealer's Avatar
Right from the factory out of the owners manual.
04 - Vehicle Quick Reference/Maintenance Schedules/Description
MAINTENANCE SCHEDULES - 6.7L CUMMINS TURBO DIESEL
CAUTION: Failure to perform the required maintenance items may result in damage to the vehicle.
Proper operation of four-wheel drive vehicles depends on tires of equal size, type and circumference on each wheel. Any difference in tire size can cause damage to the transfer case. Tire rotation schedule should be followed to balance tire wear.
At Each Stop for Fuel
Check the engine oil level about 15 minutes after a fully warmed engine is shut off. Checking the oil level while the vehicle is on level ground will improve the accuracy of the oil level reading. Add oil only when the level is at or below the ADD or MIN mark.
Check the windshield washer solvent and add if required. When refilling the washer fluid reservoir, take some washer fluid and apply it to a cloth or towel and wipe clean the wiper blades, this will help blade performance.
Once a Month
Check tire pressure and look for unusual wear or damage.
Inspect the batteries and clean and tighten the terminals as required.
Check the fluid levels of coolant reservoir, brake master cylinder, and transmission and transfer case (if equipped), add as needed.
Check Filter Minder™. Replace air cleaner filter element if necessary.
Check all lights and all other electrical items for correct operation.
Drain water from the fuel filter.
At Each Oil Change
Change the engine oil filter.
Inspect the exhaust system.
Inspect the brake hoses.
Inspect the U-Joints (if equipped) and front suspension components.
Check the automatic transmission fluid level.
Check the manual transmission fluid level.
Check the coolant level, hoses, and clamps.
Lubricate outer tie rod ends.
Lubricate Front Drive Shaft Fitting
Inspection and service should also be performed anytime a malfunction is observed or suspected. Retain all receipts.
Oil Change Indicator System
Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Required�? on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your personal driving style. Driving styles such as frequent stop and go type driving can increase the frequency of the engine oil change. This is the result of more frequent regeneration of the exhaust aftertreatment system, which can decrease the life of the engine oil. Failure to change the engine oil per the maintenance schedule can result in internal engine damage.
For information on resetting the Oil Change Indicator message, refer to “Oil Change Required – If Equipped,�? under “Personal Settings (Customer Programmable Features)'�? in the “Electronic Vehicle Information Center (EVIC)�? Section of this manual.
OIL CHANGE INDICATOR - RESET
To reset the “Oil Change Required�? indicator (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the ON position (Do not start engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Oil Change Required�? indicator did not reset. If necessary repeat this procedure.
Perform Service Indicator
Your vehicle will require emissions maintenance at a set interval. To help remind you when this maintenance is due, the Electronic Vehicle Information Center (EVIC) will display “Perform Service�?. When the “Perform Service�? message is displayed on the EVIC it is necessary to have the emissions maintenance performed. Emissions maintenance includes replacing the Closed Crankcase Ventilation (CCV) filter element, cleaning or replacement of the EGR Cooler, and cleaning or replacement of the EGR Valve.
See your local authorized dealer to have the “Perform Service�? message cleared and reset.
PERFORM SERVICE INDICATOR - RESET
The “Perform Service�? message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service�? indicator system (after performing the scheduled maintenance) refer to the following procedure:
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service�? indicator did not reset. If necessary repeat this procedure.
Miles 7,500 15,000 22,500 30,000 37,500
(Kilometers) (12 000) (24 000) (36 000) (48 000) (60 000)
[Months] [6] [12] [18] [24] [30]
Change engine oil and engine oil filter. (Under no circumstances should oil change intervals exceed 7,500 miles (12 000 km) or 6 months, which ever comes first). X X X X X
Lubricate Front Drive Shaft Fitting (4X4). X X X X X
Rotate tires. X X X X X
Check spare tire for proper pressure and correct stowage. X X X X X
Lubricate outer tie rod ends. X X X X X
Check transfer case fluid level (4X4). X
Change front axle fluid (4X4). X X
Change rear axle fluid. X X
Replace fuel filter element. X X
Inspect brake linings. X
Inspect and adjust parking brake if necessary. X
Inspect fan hub. X
Inspect damper. X
Inspect front wheel bearings. X
Inspect drive belt, replace as necessary. X
Miles 45,000 52,500 60,000 67,500 75,000
(Kilometers) (72 000) (84 000) (97 000) (109 000) (121 000)
[Months] [36] [42] [48] [54] [60]
Change engine oil and engine oil filter. X X X X X
Drain and refill transfer case fluid (4X4). X
Change front axle fluid (4X4). X X X
Change rear axle fluid. X X X
Drain and refill automatic transmission fluid, change main sump filter and spin-on cooler filter (if equipped). If your vehicle is used for police, taxi, fleet or frequent trailer towing. X
Change manual transmission fluid. X
Flush and replace engine coolant at 60 months, if not replaced at 100,000 miles (160 000 km). X
Inspect drive belt, replace as necessary. X X
Replace fuel filter element. X X X
Inspect brake linings. X X
Inspect and adjust parking brake if necessary. X X
Inspect fan hub. X
Inspect damper. X
Replace Crankcase Ventilation Filter (CCV). X
Clean EGR Valve**. X
Clean EGR Cooler**. X
Miles 82,500 90,000 97,500 100,000 105,000
(Kilometers) (133 000) (145 000) (157 000) (160 000) (169 000)
[Months] [66] [72] [78] [84]
Flush and replace engine coolant, if not replaced at 60 mos. X
Inspect drive belt, replace as required.* X X
Inspect fan hub. X
Inspect damper. X
Miles 112,500 120,000 127,500 135,000 142,500 150,000
(Kilometers) (181 000) (193 000) (205 000) (217 000) (229 000) (241 000)
[Months] [90] [96] [102] [108] [114] [120]
Change engine oil and engine oil filter. X X X X X X
Lubricate Front Drive Shaft Fitting (4X4). X X X X X X
Rotate tires. X X X X X X
Check spare tire for proper pressure and correct stowage. X X X X X X
Lubricate outer tie rod ends. X X X X X X
Flush and replace engine coolant at 120 months, if not replaced at 100,000 miles (161 000 km). X
Inspect drive belt, replace as required.* X X X
Drain and refill automatic transmission fluid and change main sump filter and spin-on cooler filter (if equipped). X X
Inspect fan hub. X X
Inspect damper. X X
Inspect front wheel bearings. X X
Adjust valve lash clearance. X
Clean the EGR Valve. X
Clean the EGR Cooler. X
* This maintenance is not required if belt was previously replaced.
**The EGR Valve and EGR Cooler maintenance will be covered by the manufacturer only at this maintenance interval, for vehicles registered in California, Maine, Massachusetts, New York and Vermont.
WARNING: You can be badly injured working on or around a motor vehicle. Do only that service work for which you have the knowledge and the right equipment. If you have any doubt about your ability to perform a service job, take your vehicle to a competent mechanic.
Gene Ashton Service Dir.@Christopher's Dodge World. 07 6.7 Mega 4x4 68RFE Laramie 6" lift 37" Mickey ATZ's Leer Topper RetroSolutions 55w HID's Amp Research powerboards Bilsteins H&S MM S&B cold air
DenverDodgeDealer is offline
The Following User Says Thank You to DenverDodgeDealer For This Useful Post:
armymech (04-12-2012)
post #4 of 10 (permalink) Old 04-12-2012, 04:53 AM Thread Starter
armymech's Avatar
Thanks, yeah i dont have the manual with me =/
armymech is offline
post #5 of 10 (permalink) Old 04-12-2012, 10:43 AM
I think you can now down load a manual from dodge for free
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
The Following User Says Thank You to MPD106 For This Useful Post:
mustard (06-28-2016)
post #6 of 10 (permalink) Old 05-05-2013, 11:53 AM
Has anyone converted this schedule to a table or spreadsheet so the X line up with the mileage?
And would you please share it???
2009 3500 Laramie, auto, LWB, Hillsboro alum flatbed, Mini Maxx, dpf gone, 31k mi
009RAM is offline
post #7 of 10 (permalink) Old 05-05-2013, 12:07 PM
If you go to CarboniteCummin.com you can download a complete shop manual for the 2008 6.7. It is 10000 pages and took me about a half hour to download but most of it should apply to the 2007 also. It is a private persons website not a commercial one.
stovein is offline
post #8 of 10 (permalink) Old 05-05-2013, 12:09 PM
Oops, should have read CarboniteCummins.com
stovein is offline
post #9 of 10 (permalink) Old 05-05-2013, 02:14 PM
7492's Avatar
Yes, It's in the owners manual.
07 Megacab 3500 4x4 6.7Liter 68RFE 22 MPG highway.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #10 of 10 (permalink) Old 05-05-2013, 04:56 PM
5.9 PWR'D's Avatar
I've had my truck for a year now, still have the emissions on the truck. I do my oil, oil filter and air filter every 10000km fuel filter every 20000km my mechanic laughed at me for doing my fuel filter every 10000km because it was so clean (good clean fuel helps that) and I do my tranny filters,full flush and my differentials once a year. So you can draw your own conclusions from this
Daniel M. Local 721 Ironworker Apprentice | 2007.5 2500 Megacab(IRP) ... CCV Bypass, Bilsteins, Deletes on the way
5.9 PWR'D is offline
