6.7 fuel filter - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 20 (permalink) Old 10-26-2011, 10:24 PM Thread Starter
8nfever1952's Avatar
6.7 fuel filter
After 45k miles I think I need to be changin my factory fuel filter on my 07 2500. I was told by a dodge dealership on ebay that sinse it was my first filter change I would need to purchase the entire fuel filter housing assembly (70 bucks). They told me after I "upgraded" my filter housing I could then get away with just purchaseing the filter element (15 bucks). Is this a true fact or is someone giving me the run around here? Thanks in advance for your help!
8nfever1952 is offline
post #2 of 20 (permalink) Old 10-26-2011, 10:29 PM
scubieman's Avatar
Your suppose to change every 15 k. And yes you need new housing. The extra filter is 35 bucks. The 5.9 fuel is like 20.
2009 Dodge Ram 6.7 with Smarty JR on Fuel economy and 99% POD. 119k . DPF delete, EGR and EGR cooler removed. Fuel Pressure/Boost/Pyro Autometer Gauges, Auto Engine Brake .
scubieman is offline
post #3 of 20 (permalink) Old 10-26-2011, 10:30 PM
Sounds like the right story. They upgraded the fuel filter from 7 micron to 5
somewhere mid 08, and that is the only filter available now. You need a new
shell + filter the first time, and then you can change just the element.
Don't wait for another 45k to change it. Change it every 15k.
2008 6.7 Quad cab SB, G56, 3.73, black, Edge Insight, 285-70/17 BFG, Bilstein 5100 shocks, MagHytec rear diff cover, otherwise all stock.
2000rpm is offline
The Following User Says Thank You to 2000rpm For This Useful Post:
pbbert (10-23-2014)
post #4 of 20 (permalink) Old 10-26-2011, 10:41 PM Thread Starter
Thanks for the reply's. I just wanted to make sure I wasn't get jerked around. I have no idea why I haven't changed it yet but it will deffinetly be happening this week!
post #5 of 20 (permalink) Old 10-27-2011, 10:22 AM
ETS
45k miles??!!! Wow, you're lucky that the truck still starts! I've seen several trucks (including my own) with less than 20k on the filter have driveability problems. Definitely stay on top of it more next time around or you could have trouble.
ETS is offline
post #6 of 20 (permalink) Old 10-27-2011, 01:11 PM
DieselRiot's Avatar
iTrader Score: 5 reviews
I usually go every 3 to 4 oil changes till I replace it depending on mileage
Sent from my DROID2 using Tapatalk
2008. EFI Live By Cummins-Tuner. Copilot. 5" TBE. S&B Intake With Scoop. GDP Mega-Flo With Boost Tube. GDP Pro-Gate. GDP CCV Delete. WCC Silencer Ring Mod. Rail Shim. Fass Ti 150. ARP 425's.
DieselRiot is offline
post #7 of 20 (permalink) Old 10-27-2011, 07:31 PM
7492's Avatar
Unless you have a supply of the old filter like I do.
07 Megacab 3500 4x4 6.7Liter 68RFE 22 MPG highway.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #8 of 20 (permalink) Old 10-27-2011, 10:46 PM
I just replaced mine. It was $54 from the dealership for the 2010 diesel filter.
2010 Dodge Ram 2500 CTD MC 4x4 Laramie - MBRP 4in TBE w/ muffler, Mini Maxx w/ MCC from TSD, ARP 625 Studs, Sinister EGR Delete
HemiAg is offline
post #9 of 20 (permalink) Old 10-28-2011, 11:30 AM
Yahooligan's Avatar
Hopefully you change your oil every 4000-5000 miles if that's the case.
Filters are cheap, fuel systems aren't. I don't see why anyone would risk expensive repairs by going beyond the 15k mile interval unless they simply didn't know it needed to be replaced at that interval.
2007.5 3500 MegaCab SLT SRW 4x4 6.7L, 68RFE w/ Mag-Hytec, XRT Pro, Diamond Eye DPF Delete, leveling kit w/ Bilstein 5100s, SnugTop Rebel shell, Insight CTS, Hell Bent Steel SBS - SOLD
Yahooligan is offline
post #10 of 20 (permalink) Old 10-28-2011, 06:41 PM
MattTse's Avatar
oh my..... im at 79 KILOMETERS and i havent touched it... it never said anything in the warranty or maintenence, at least i cant reacall seeing it. well at least nothing has happened to the fuel system.
09 3500 laramie 6sp 5" turbo back, all deletes, mini maxx 3600 DD clutch, II BOP, 5.9 intercooler.
MattTse is offline
post #11 of 20 (permalink) Old 10-28-2011, 07:22 PM
Yahooligan's Avatar
If you bought it new and didn't change the fuel filter ever then your truck shouldn't be running right now.
And it is in your owner's manual in the maintenance section...
15,000 Miles (24,000 km) or 12 Months Maintenance Service
Schedule
❏ When prompted by the Engine Oil Indicator System, the engine oil and filter must be
changed. If not prompted by the Engine Oil Indicator System within 7,500 miles
(12 000 km) or 6 months since the last oil and filter change, change the engine oil and
engine oil filter. Under no circumstances should oil change intervals exceed 7,500 miles
(12 000 km) or 6 months, whichever comes first.
❏ Rotate tires.
❏ Lubricate front drive shaft fitting (4x4).
❏ Lubricate outer tie rod ends.
❏ Change front axle fluid (Ram Truck/Chassis Cab 4x4).
❏ Change rear axle fluid (Ram Truck Only).
Replace fuel filter element.
Every other oil change is how I do it, easy way to remember too.
post #12 of 20 (permalink) Old 10-28-2011, 08:26 PM
UtahBruteForce's Avatar
That's how I do it too. Every other oil change, I include the Air Filter, Fuel Filter and MAP sensor cleaning.
2009 Ram 3500 4x4 Mega Laramie/Resistol DRW
BFG KM2 MT's, 3.73 Gears, 18K SuperGlide, P3, Airbags, Deleted, Black Maxx w/OD, Flo-Pro, Mag-Hytec Trans & Diff Cover, 6" MBRP Tip, Aux Trans Cooler
UtahBruteForce is offline
