Smell burning rubber, smoke from wheel well - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 12 (permalink) Old 12-24-2007, 05:28 PM Thread Starter
its an 08 2500 QC SB with 2600 miles. Smetimes after i back into the garage and shut it off, i smell burning rubber. i looked at the under carriage and didnt see anything. looked in the passenger side front wheel well and there was smoke coming out. not much, but enough to concern me. looks like it could be coming from the turbo, but not sure. smoke was gone when i popped the hood.
no problems, no cel, and it doesnt feel like anything is wrong. anyone have a similar problem?
ms2428 is offline
post #2 of 12 (permalink) Old 12-24-2007, 05:31 PM
Bomaster238's Avatar
was your belt squeaking at all? maybe the belt is just slipping enough to cause some smoke. check it for wear or cracks. I know its a new truck but who knows. my buddy has an 07 and the AC compressor seizes sometimes and it really cranks when you turn the AC on to get it goin. maybe you have a bad ground somewhere that is shorting something out and causing a wire to melt. Its a new truck so its hard to tell
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline
post #3 of 12 (permalink) Old 12-24-2007, 05:59 PM
Mine stinks to all hell when I turn it off during a regen however it's more of a 'really hot metal' (thinking welding) smell than a burning rubber smell I'm told the stench is normal up to about 5000 miles but I don't have any smoke to go with it.
Check for any hoses or wires that might be too close to the exhaust system.
slagburn is offline
post #4 of 12 (permalink) Old 12-24-2007, 06:12 PM
did you possibly just get an oil change done?
maybe if its still super new then there is stuff burning out of the or off of the exhaust somewhere.
why not go get it checked out at the dealership
00 Dodge Ram 2500 4x4
carter lp,Super B Special, mbrp 4", juice w/att, homemade intake, 33's, three trannies later---> almost enough power
DRFTR is offline
post #5 of 12 (permalink) Old 12-24-2007, 07:22 PM Thread Starter
im bringing it in this week. but i have to drive 400 miles tomorrow and am a little worried about breaking down. hopefully itll be ok
ms2428 is offline
post #6 of 12 (permalink) Old 12-24-2007, 07:22 PM
stevewix's Avatar
mine does it as well, from what i've personally noticed a pyrometer gauge is one of the best purchases you can make for your truck. There's a good chance it's in regen when you're shutting it off, I've caught mine 800-950 degrees (stopped) even after idling around a parking lot until I find a spot. Every time I get the rubber smell it's in regen.
2008 Dodge Ram 2500 Laramie Quad Cab - Short Box - 6.7L/68RFE - H&S XRT - 5" TBE - EGR Delete - B&W Turnover Ball - Defiant Light Bar - Firestone Air Ride.
stevewix is offline
post #7 of 12 (permalink) Old 12-24-2007, 08:33 PM
atc250r18's Avatar
I'd agree it's probably just in regen. I have found that if I drive mine around in a parkng lot or just sit and idle then the EGT's drop to about 650 and I don't get the smell. If I shut it down at an 800-900 degree EGT than I defedently get the "melting" smell. If your EGT sensors down by your dpf and NOx trap get to somthing like 570 then the truck will come out of regen and you won't shut if off during a burn cycle. Somthing we all have to deal with. Oh well, I still love this truck. It's way more comfortable than my 1st gen.
07 Mega cab. !!SUBMARINES!!
atc250r18 is offline
post #8 of 12 (permalink) Old 12-25-2007, 01:58 AM
I thought this was going to be a post about the power these 6.7s have. Figured it was tire smoke and burning rubber.
I never smell burning rubber up front, but I also smell the hot metal/welding smell sometimes and I figure it was probably in regen when I shut it off.
2012 Laramie - 6.7 - CCSRW4X4 - 6-Speed Auto - 4:10 - Edge CTS - Mag Hytec - 2" Hellbent Leveling - BD Adjustable Track Bar - Ride Rites - PullRite 5th Wheel Auto Slider
Flattman is offline
post #9 of 12 (permalink) Old 12-25-2007, 10:28 AM Thread Starter
i thought that when it was in regen the overhead console indicated so..??
anyway, yeah the power is great. i love this truck. i traded an 06 QC SB Laramie 5.9 for this one and im very happy i did. the 6 spd auto is the main reason i traded. the 6.7 and jake brake are awesome too. it also feels like it rides much smoother and tighter. just wish we could have it without the dpf. thinking of getting the delete, but i dont want to jeopardize my warranty.
merry christmas!
ms2428 is offline
post #10 of 12 (permalink) Old 12-25-2007, 12:51 PM
The overhead indicates when the catalyst is full however it doesn't tell you when the truck is going through a regen cycle; some say that they can tell because the mileage drops off suddenly but I haven't found that to be 100% accurate where I live since I can seldom maintain a steady speed for any length of time and don't really drive many truly flat roads.
Best bet is to either have a programmer that can monitor the EGT / regen process or install gauges.
slagburn is offline
post #11 of 12 (permalink) Old 12-25-2007, 01:35 PM
dodgetuff's Avatar
Thats why they call it new ,not even worry ,take it back you paid for them to look .
Thats why they call it new .Not even a wreyie
Rollin 'on an 08' 4x4 6.7L Dodge Dually, 6 Speed Auto,3.73 Custom Front/Rear Bumpers, NFab Running Boards, B&W Goose Neck Trailer Hitch. Powered by Bay Area Diesel Performance 5'' tbe 6''tip [size does matter] edge w and juice attitude
dodgetuff is offline
post #12 of 12 (permalink) Old 12-25-2007, 02:35 PM
JASE4X4's Avatar
Yeah, I got that burning rubber smell too. I noticed it when I pulled in to the driveway. Truck was still idling and the exhaust was extremely hot. It must have been in regen when I stopped. The smell was coming from the rear of the truck. I think the exhaust hangers are getting hot and the smell is coming from the rubber isolater.
JASE4X4 is offline
