H&S Mini / Black Maxx for towing - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 5 (permalink) Old 02-24-2011, 07:44 PM Thread Starter
UtahBruteForce's Avatar
I finally have the funds for a full EGR/DPF delete and tuner. After reading many posts regarding the H&S, it seems the general consensus is that when towing, the SHIFT patterns are terrible after adding the H&S product.
I am looking to do the deleted + tuner to improve towing my 42' 5th wheel and for the possible +4mpg increase in fuel economy.
Any input and direct personal experience with towing/fuel mileage appreciated.
2009 Ram 3500 4x4 Mega Laramie/Resistol DRW
BFG KM2 MT's, 3.73 Gears, 18K SuperGlide, P3, Airbags, Deleted, Black Maxx w/OD, Flo-Pro, Mag-Hytec Trans & Diff Cover, 6" MBRP Tip, Aux Trans Cooler
UtahBruteForce is offline
post #2 of 5 (permalink) Old 02-25-2011, 12:04 AM
Regen? What's That??
azpyroguy's Avatar
I run my H&S Black Maxx, with Trans Overdrive software, and tow my 40 foot fifth wheel, which weighs about 15-16k.
I only tow in MILD tune, and if need be will sometimes drop back to No Power if temps get too out of line (pulling a grade, etc..)
I also keep a close eye on my trans and EGT, and have my wastegate set to open up at 32psi.
I average around 12mpg when towing with this setup.
I have my defuels set at:
1450 EGT
210 Trans Temp
220 Coolant Hot
170 Coolant Cold
32psi Boost
These seem to work quite well. I don't lay into the throttle when towing, I let the engine spool up slowly, and make sure things are not stressed... been doing it this way for about 2 years without issues. I added the over drive software last July and its been even better.
07 3500 QC DRW, 6.7, Auto, AirAid Intake, H&S 4" TBE-BlackMaxx-TCM-+Complete EGR Delete, RBP Tailpipe, BrakeMan Brakes, BME EWG, HID's, MagHyTec Diff/Trans, Shibby Boost Tube, Stage 2 Horn, TVD, ISSPro Gauges, Amsoil, Pioneer, Sirius, Rockford 3Sixty.2, RF/MB Quart Mids/Highs, Rockford & Kenwood Amps, ProBox Rocks Dual 10" subs, Hornblaster Train Air Horns, Magnaflow CAT.
azpyroguy is offline
The Following User Says Thank You to azpyroguy For This Useful Post:
Speedylifsavr (02-25-2011)
post #3 of 5 (permalink) Old 02-25-2011, 12:47 PM
I'm only towing about 10,000 lbs, but keep the MiniMaxx set for no power and just love the fuel economy. I usually set the stock transmission in tow/haul mode and it works fine.
When towing, I usually do not turn on the engine brake unless I need it, typically after leaving the freeway and getting onto side streets. I'm not fond of the aggressive downshifting that the tranny will do if you have tow/haul mode on and the engine brake engaged.
Scott (Boydski) Boyd
2009 Quad Cab 2500 4x4, Auto, Mini Maxx, H&S stage 2 TBE, Bilstiens, 34" Nittos, BD Steering Stabilizer, Spitzlift Crane, looks stock.
Boydski is offline
post #4 of 5 (permalink) Old 02-25-2011, 04:55 PM
Speedylifsavr's Avatar
1450 EGT
210 Trans Temp
220 Coolant Hot
170 Coolant Cold
32psi Boost
Do you use tow/haul and/or the transbrake when you tow . I am curious because I also have the blackmaxx with the tcm tune . I have a 9000 lb travel trailer but have not towed it yet since I modded my truck . I was wondering how tow/haul would perform with overdrive?
2007.5 3500 6.7L 4X2 QC LB- fully deleted with H&S deletes . FloPro 5" TBE , MBRP 6" tip . H&S BlackMaxx w/Overdrive , H&S intake horn , H&S boost tube , Shibby grid heater delete , K&N drop in
[SIGPIC][/SIGPIC]
Speedylifsavr is offline
post #5 of 5 (permalink) Old 02-25-2011, 07:40 PM
mello03's Avatar
I am curious about this too. I won't tow for another month or so but plan on just using the EB and not the Tow Haul since I only tow about 6K mostly highway. I just put the OD software on so wanting to baby the trans as much as possible.
2010 CC TRX 4X4 68RFE 4.10
Carli 2.0 with sway, Bushwackers, Pattonfab Lightbar, Lightforce, AFE CAI, Centerline Grizzlies, 35" MT ATZs, and H&S MM w/OD
mello03 is offline
