Sway bar linkage lift extention? - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 21 (permalink) Old 05-17-2017, 09:52 AM Thread Starter
thequintessentialman's Avatar
Somehow I managed to bend one of the links (and rip ball joint out of socket,) that fits between the sway bar and where it bolts in at bottom. I got a couple of Moog replacements from local "car parts are us" but then realized there is a 6.3 inch extension that apparently compensates for the lift. I'm not having much luck tracking down this part online. It's basically just a long coupling nut but has a stud at one end.
Any ideas or suggestions?
Thanks
It is by caffeine alone I set my mind in motion. It is by the juice of canephora and arabica that thoughts acquire speed, the hands acquire shaking, the shaking becomes a warning. It is by caffeine alone I set my mind in motion.
thequintessentialman is offline
post #2 of 21 (permalink) Old 05-17-2017, 10:59 AM
lpennock's Avatar
Get correct link links and don't mess with bandaid extensions.
Sent from my SM-T350 using Tapatalk
Leonard Pennock AD7AS
2006 Ram 3500 4x4 6sp, F&R TrueTrac, EFI Live, GT3782R, Dual Disc
2008 Ram 5500 4x4, ATS7500/VGT, 2xCP3, Suncoast AS68RC, Black Maxx
lpennock is offline
post #3 of 21 (permalink) Old 05-17-2017, 11:17 AM Thread Starter
OK, I have relatively little experience with this. The linkage kit was installed by the dealer; it was sitting on the lot with lift installed, as is, when I bought the truck new (and have since found out it was not the premium lift kit.) Could you possible be more specific. FWIW, they worked fine for 9 years and it was the OEM part that bent, not the extension. I'm open to suggestions but I already have the two new links and kind of want to get this fixed ASAP. Mechanically it seems really simple after getting the nuts loose, finding the correct parts is the challenge.
Thanks
post #4 of 21 (permalink) Old 05-17-2017, 11:45 AM
lpennock's Avatar
A couple companies make extended links. Skyjacker, Tuff Country, Cali, and others. They come for different size lifts.
Can you post a picture of the part you need? Do you have any idea on the lift brand? Might help ID what you are looking for
lpennock is offline
post #5 of 21 (permalink) Old 05-17-2017, 01:11 PM
GloNDark's Avatar
Lots of companies make them. You will need to measure the ones you have first (the non destroyed one ) and take your pick.
Some are cheaper than others, and some are downright crazy priced. But a google search for "Dodge 2500 Extended Sway Bar end links" will get you a ton of options.
https://www.suspensionconnection.com...-endlinks.html
Geno's garage has a bunch of Options:
https://www.genosgarage.com/category/sway-bar-links
My favorite go to shop CJC Offroad has a bunch of higher end options as well
DT Pro Fab Dodge Ram 2500/3500 4x4 Sway Bar End Links
2008 Dodge 2500 Laramie 4x4 68rfe and a few goodies
GloNDark is offline
The Following User Says Thank You to GloNDark For This Useful Post:
Rhinopkc (05-17-2017)
post #6 of 21 (permalink) Old 05-17-2017, 01:33 PM
That Truck Guy
Skyd Ram's Avatar
iTrader Score: 8 reviews
Thanks
Sounds like it may be a Superlift part that you have on your truck. How much lift do you have altogether?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Dynatrac
Synergy Suspension | Fox Shocks| aFe Power | S&B | SOTA Wheels| Air Dog | Amp Steps
TRUCKBOSS Sled Decks | Spicer | ARP | REV-X | RIGID Industries | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 21 (permalink) Old 05-17-2017, 01:48 PM Thread Starter
Apparently external storage is required for a pic. May be later tonight...
post #8 of 21 (permalink) Old 05-17-2017, 06:31 PM Thread Starter
https://www.dropbox.com/s/6biheh32a2...1946.jpeg?dl=0
post #9 of 21 (permalink) Old 05-17-2017, 06:43 PM Thread Starter
The ones from Suspension Connection and DT Pro have another ball joint at the top. Mine has only one at the the right angle on the bottom. Is that better or a different part?
post #10 of 21 (permalink) Old 05-17-2017, 06:54 PM
Paul@CJCOFFROAD.COM
Rhinopkc's Avatar
Having a pivot point at both ends can help prevent binding.
Give Us a Call for All Your Suspension, Lighting, Wheel, and Tuner Needs!
Carli systems free shipping to Canada and U.S.A. Free 2-day air on Carli Ball Joints
424.241.3252 x700
Rhinopkc is offline
post #11 of 21 (permalink) Old 05-17-2017, 07:03 PM Thread Starter
This is a pic of the good one and the bad one.
(There is a little icon above this panel that says insert picture; it's a ruse, don't fall for it...)
ID:	652937   Click image for larger version
post #12 of 21 (permalink) Old 05-17-2017, 07:38 PM Thread Starter
OK, I measured the old one. The bushing" part, the solid part between the chassis and the OEM link is 4". That stands to reason, it's supposed to be a 4" lift.
