Well, I threw this code tonight and have read a couple of posts on this and I was wondering if there is any new developments on fixing this other than the dealership or deletes. I run exhaust brake on all the time and my insight shows my soot to be at 3.7% making me think that my truck is pretty clean. I'm wondering if I could drive the piss out of it and see if the EGR Valve shall unstick itself or if I need to take it to the dealer. Let me know what ya'll think. 11500 miles on the clock.
Thanks in advance,
Jim
2008 QC 4x4 SLT Big Horn Mineral Grey, B&W Hitch, Spray in Bedliner, S&B CAI, Edge Insight, Firestone Air Bags, WAS Stock
Well, I may call the stealership and see what the recommend and then do nothing! One things for sure, I DO NOT want a new flash. I'll keep driving it though. From my earlier readings people said it was fine to keep driving. More incentive to do the deletes.
its from ur intake... i used to get it with my S&B and boost fooler.
__________________ Had:2k 24V Little of this and that
Had:09 5% TINT DELETED XRT ISSPROS SBC 3600 BUSH WACKERS
12' 5% TINT DELETED H&S MM 35'' BFG KM2s
And did you do anything to fix it?
Nye, I'll let you know. But I am doing everything within my power to stay away from the dealership. It's amazing that so many goobers work at one location instead of spread out over many locations.
I wouldn't worry too much about it. Mine throws that code every once in a while but will clear itself after a few restarts. If it sticks around more than a few restarts, then I would take it in.
smarty lol. no i blocked off my egr and just get that one code for egr
Dealership mechanic is doing everything he can to help out. I told them that I would have to have a comparable truck that could tow 15000+ since I was in the middle of hauling hay. The mechanic said that this was something I would have to get used to (soot on my EGR Valve) and that this would become a routine thing for us 6.7 guys. He said I probably needed the newest flash and I told him there would be no way he would flash my truck and he said "you guys must be forming a pact because you aren't the first guy to say that." He asked if I was concerned with them locking my ECM which I was. He then told me that he could send me home with a cleaned EGR and I could fix the problem myself if I wanted to (he was serious and nice about it so I didn't think he was just being a ) to save me some time. I might take him up on that offer if I don't do the deletes before I have a problem. He said that I would probably be driving down the road some day and the truck would just fall on its face because the DPF was sooted up completely. I am seriously considering the deletes now because I shouldn't have to have a "routine" cleaning on my EGR just to keep my truck functional. It's like driving these trucks is becoming a privilege and work all at the same time. Let me know what y'all recommend on the deletes and what is necessary as far as egr delete do I have to delete the cooler etc...
Once again thanks in advance,
Jim
Hi
As others have already chimed in, p0402 can be an erroneous code and not necessarily related to a real fault condition. The TSB 18-024-09 that I posted was abbreviated and I took another look and found the post did not contain the portion.
__________________________________________________ ______________
SYMPTOM/CONDITION:
The customers may experience:
a. An erroneous MIL illumination for P2262 - Turbocharger Boost Pressure Not
Detected - Mechanical.
b. Improved diagnostics for P2299 - Brake Pedal Position / Accelerator Pedal Position
Incompatible.
c. An erroneous MIL illumination for P0402 - Exhaust Gas Recirculation (EGR) Flow
Excessive Detected.
d. An erroneous MIL illumination for P040B - EGR Temperature Sensor 1 Circuit
Performance.
e. An erroneous MIL illumination for P0405 - EGR Position Sensor Circuit Low.
The flash BD/AV contains a number of functional improverments and is highly recommended .
It could prevent several failures from occuring and save you many bucks in the long run.
It does NOT contain any stealth programs that will lock up your ecm.
Just my 2 cents.
Charlie
The Following 2 Users Say Thank You to RegenerationCompleted For This Useful Post:
Do you recommend doing the deletes? EGR/DPF??? If you do, what TBE do you recommend I want to go with a 4" but do you have a preference on brands? Let me know what you think. Or anyone else who wants to chime in!
