09 turbo cleaning - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7 Liter General Discussion
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
Old 08-15-2009, 09:50 AM   #1 (permalink)
09 turbo cleaning
I am shopping for a CTD. Have not owned one yet. I have read that the 09 has a door on the turbo for the purpose of cleaning out soot. Has anyone cleaned theres? Just wondering how easy this is? Do you spray in carb cleaner or something similar? And is it really a viable solution to the soot problem?
Chris
C-WEED is offline   Reply With Quote
Old 08-15-2009, 09:58 AM   #2 (permalink)
john_ak's Avatar
It should be a cleaning port, not a door. All the newer turbos have the cleaning port because of the p2262 problems. Shouldnt be too hard just unbolt it and spray the recommended cleaner in there.
sold: '07 2500 QCSB 4X4 6.7 Auto, XRT, Airaid intake, 5" TBE to 6" mitres
john_ak is offline   Reply With Quote
Old 08-15-2009, 10:14 AM   #3 (permalink)
Interesting. I wonder if this is done with the turbo at idle or with the engine off?
Old 08-15-2009, 11:38 AM   #4 (permalink)
GloryOleAU94's Avatar
This tool is used in conjunction with MOPAR Part Number 68044565AA, Turbo Cleaning Solvent, during service procedures on Cummins 6.7 Liter Engines. NOTE: Refer to TSB for procedures.
Miller Special Tools 10142 CUMMINS TURBO CLEANING KIT
Haven't found the procedure yet. Still surfin...
2007 Mega Cab 2500, 6.7L Cummins, 6-speed manual, Stock
ProFlaps and Rhino Dominator III steps
& 2001 Dodge 1500, 5.9L Gasser - exhaust mods
GloryOleAU94 is offline   Reply With Quote
Old 08-15-2009, 11:52 AM   #5 (permalink)
Here's the TSB. Requires replacing the O2 sensors w/plugs, running the engine to heat it up to temp, then 3 cleaning cycles w/3 cans of solvent (~5 mins each). Then several ignition key cycles, clean & replace O2 sensors. Tool posted above is $250.
http://wiki.dieseltruckresource.com/.../11-001-08.pdf
Old 11-13-2009, 01:12 AM   #6 (permalink)
Does anyone know if this is an effective long term solution? Other Holset VGT turbos are having the same problem, and the turbos are exploding because of it. I would like to recommend this solution, but I don't know if it is real or not.
Ive taken down plenty of these vgt units, and the problem as I see it is that the buildup would not simply dissapear if you spray it with some solvent-the VGT assembly goes inside of the bearing housing. We usually take the whole turbo down and clean it because of this.
I could see this as a maintenance solution after a full overhaul is done, but I don't see this taking all of the carbon out. Anyone?
Colorado Turbo Repair is offline   Reply With Quote
Old 05-13-2011, 09:35 PM   #7 (permalink)
Colorado Turbo Repair i strongly agree with you i have an 07.5 6.7 dually an waited to long to change my ccv then got 2262 idk how much a flush runs im obviously out of warranty an dont want that done any way ive looked for good tut on how to pull an clean the turbo but had no luck im a real do it yourselfer so here it is im in the procces of pulling my turbo right now an i started by pullin my mud flap then oil feeder an coolant inlet an inner cooler line an intake loosened the band on the elbow an the back of turbo then oil return line an coolant return line now ive got two bolts off the turbo where it mounts to the exhaust manifold ...lol any advice how to get the other to bolts off (two by the block) an any advice how to clean it an what to use ? i heard break cleaner but isn't that bad for gaskets ? an i heard carb cleaner isn't that combustable ?...i figured soapy water an a tooth brush ? any help would be greatly appreciated thanks
Dustin L
DustinL505 is offline   Reply With Quote
Old 05-14-2011, 03:05 PM   #8 (permalink)
airborneRGR's Avatar
iTrader Score: 5 reviews
Dustin L
I made a thin 15mm box wrench to fit on those two bolts your talking about. I just bought a cheap 15mm from the auto parts store and went to work on it with my bench grinder.......I really didn't want to pull the exhaust manifold.
You can clean your turbo with Seafoam and a wire wheel.
2008 6.7 2500 MEGACAB, 4x4, Mini Maxx, ATS stage 3 with Copilot, FLOPRO 5 inch TBE,H&S Maxx Flow, H&S Boost Tube, H&S Cooler Delete, S&B CAI, ARP 425's, GDP CCV breather, GDP Pro-Gate 38mm, Mag-Hytec Trans Pan, Mag-Hytec front & rear Diff Covers, ISSPRO EV2's, Retro Solutions HID 8000k Headlights & Fogs, Firestone AirBags, BD Steering box brace, Carli Swaybar Links, Carli Ball Joints, Carli Trac Bar
airborneRGR is offline   Reply With Quote
