H46 Recall - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 8 (permalink) Old 06-27-2009, 03:28 PM Thread Starter
wildcat05's Avatar
H46 Recall
The dealer called me the other day and wanted me to come in and have the H46 inspection done. My question is should I go do it or will they lock my ecm with a new flash like the new 09's have. I am planning on deletes and XRT soon and just curious what you all thought.
Thanks
07' 2500 MC, 4X4, 6.7, Auto, SLT, XRT, 5" TBE, H&S EGR and Cooler delete, S&B intake, Isspro EV2's
01' 2500 QC, 4X4, 5.9, Auto, Sport, BHAF, No silencer Ring, 4" Straight, MagHytec
wildcat05 is offline
post #2 of 8 (permalink) Old 06-27-2009, 03:39 PM
Thanks
i went in for the recall and all they did was inspect mine and said it was fine . they didn't even take it to the shop . the service writer looked at it in the parking lot . he said he hasn't seen one yet that needs the recall .
2007 3500 mega cab ctd 6 speed manual , drw , 6.7 3:73 rears , 4x4 , Valair single disc kevlar/ceramic 500 hp/1000 ft lb clutch ,H & S egr/egr cooler delete , flo pro 4 " turbo back exhaust , k and n air filter , smarty
Dawg is offline
post #3 of 8 (permalink) Old 06-27-2009, 04:30 PM
knightag's Avatar
When I took my Truck in I told them not to re flash are I would not leave the Truck with them http://www.cumminsforum.com/forum/im...milies/doh.gif
08 Ram, Quad Cab, SLT, 4X4, Inferno Red with 5" Turbo back Exhaust, Edge Juice with Att., EGR on strike ,AIRAID CIA.
1991 Ram CTD purchased new 200,000 + miles just broke in.
knightag is offline
post #4 of 8 (permalink) Old 06-27-2009, 05:21 PM
firemansdiesel's Avatar
Thanks
Not all '09's have the new ECM. Any new truck built after March '09 has the new ECM. I also believe it's not a flash the dealer can do. It has to come w/ the new ECM. So unless you neeed to replace your ECM w/ a new one. Don't worry about it and have them look at your steering set up.
Old: 1996, 2005, 2009, 2012 CTD - All Thuren/Carli Suspended and Goodies.
firemansdiesel is offline
post #5 of 8 (permalink) Old 06-27-2009, 06:08 PM
Hi
The H46 Recall for most, is an inspection only.
To see if you need any thing done.
1/ Look at your linkage where the damper mounts to the link.
2/ If it's a stud through tie bar. No action is required.
The dealer is having the service advisors do this step so most vehicles won't even get to the shop. If you have this style, you should swing by a dealer for them to see it and process the recall paperwork so the recall will be removed from your vin.
3/ If the damper mount is a bracket with 2 u bolts to the tie bar, then it needs to at a minimum get a new inner drag link tie rod end. possibly the full monty (bracket, too).
4/Actually if you can locate a dealer that has service advisors wearing short skirts and
thongs (or less!!) have them check it for you.
Charlie
RegenerationCompleted is offline
post #6 of 8 (permalink) Old 06-29-2009, 08:52 PM
I like the way you think.
My service advisor does wear short skirts and may wear a thong,
but he really is not my type.
08 2500hd quad cab...
stock
xxbaker is offline
post #7 of 8 (permalink) Old 06-29-2009, 09:02 PM
blacksmoke101's Avatar
2013 Laramie leveled tinted and PPEI tuned
blacksmoke101 is offline
post #8 of 8 (permalink) Old 07-01-2009, 10:45 AM Thread Starter
wildcat05's Avatar
Thanks for all the input guys. I will get it in to get it checked out
