Knocking noise from motor - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7 Liter General Discussion
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
Old 04-14-2009, 04:49 AM   #1 (permalink)
PNW86's Avatar
Hi guys...recently I've noticed some knocking/ticking noise coming from the motor ( about 2 fill ups ago ). It is most significant when I'm in 6th gear (auto) just a lil above 1000rpm and i slowly start to accelerate...i hear this knocking noise coming from the motor...and it kinda goes away when I'm closer to the 2000rpm range then after that i just hear the turbo spool...and then past that I don't really hear the knocking noise...And once the truck is warmed up...if i roll up to a stop light doing less than 20km/hr at almost idle speed...every now and then i hear this louder knocking noise..and the rpm kinda bogs down maybe by a tiny bit..it is not consistent...it kinda comes and goes...but this knocking is louder than the knocking when accelerating and is annoying
So the question is...would it be just some bad fuel??? or maybe the fuel filter is clogged? I drained the fuel filter with the little drain plug and also put in some injection cleaner...it seemed to help A BIT...the truck has 26600kms and only has the egr unplugged...The airfilter is kinda dirty but it is still acceptable...I'm gonna change the fuel filter tomorrow and see if that helps...any ideas???? pleeease and thank you! thanks for reading
-Boris
2008 Dodge Ram 3500 QCSB SRW 6.7L 68rfe 3.73, Edge J/A, K&N CAI, BADP gen1 fooler, Flopro 5" TBE, EGR blocked.
PNW86 is offline   Reply With Quote
Old 04-14-2009, 12:43 PM   #2 (permalink)
PNW86's Avatar
32 views and no reply??? anyone? please....
Old 04-14-2009, 12:44 PM   #3 (permalink)
mine does th exact same thing, there was another thread on it and nobody can seem to figure it out. just my 2cents
07.5, 6.7, G56, H&S stage 2 DPF, K2 EGR, mbrp tailpipe, K&N air intake, Edge juice w/att. H&S XRT, soon to come southbend and airdog!!
6.7cumminspower is offline   Reply With Quote
Old 04-14-2009, 12:54 PM   #4 (permalink)
Kansas Cummins Crew
moparpower1985's Avatar
I would lean more to bad fuel. I would smell the fuel, and drain your fuel/water seperator into a mason jar so you can see what you got. If all those things pass inspection, then I'd add some red top power service. Let us know....
2008 Crew Cab, Debadged, G56/3.42's, Edge Juice w/ Attitude, Exhaust, Intake Baffle Removed, 5.9 Air Filter, High Idle (pto) Feature, Valair Nodular Dual Disc, Cobra 29 WX, Ramsey 8000#Ind. Winch, 2.5" Spacers Front, 2" Rear Blocks,and ProComp 35/12.50/17's
Proud U.S. Army Soldier-21E
moparpower1985 is offline   Reply With Quote
Old 04-14-2009, 01:24 PM   #5 (permalink)
CO6.7Cummins's Avatar
-Boris
I'm not sure if this is what it is, but I could hear a knocking noise as well when the truck went into regeneration. I only correlated the two when I installed my Edge Juice and was alerted when I was in regen. Everytime it happened, I'd hear the knock.
When it wasn't in regen, the knock was gone.
08 6.7L QCSB 4x4, 68RFE, deletes, Smarty, AD150
CO6.7Cummins is offline   Reply With Quote
Old 04-14-2009, 01:33 PM   #6 (permalink)
PNW86's Avatar
Red top power service is what i used as what I said as the injection cleaner...i've put abt 250ml in there on my last fill up...it seemed to have helped a bit...
-Boris
Old 04-14-2009, 05:47 PM   #7 (permalink)
Could it be the turbo actuator cycling????? You know the exh. brake sliding vein not having the end points adjusted properly????
08 srw 4x4 q/c black laramie a/t
Smarty,Edge w/att hot,5" tbe BADP,K2 egr and cooler delete,ARP STUDS, Sun coast T/C 3, airdog2 165,shimmed rail,fire ringed, 2 JL13 w7's,JL1000/1(ridiculous)
grasmo is offline   Reply With Quote
Old 04-14-2009, 06:00 PM   #8 (permalink)
PNW86's Avatar
Well...I just got home from a 150km drive...when i turned onto my street...i was doing abt 30km/hr and the engine was almost at idle speed...and i was just coasting in whatever gear slowing down...i heard that knock...it just went...knock knock knock knock knock knock.......knock....knock knock knock...I really dunno what it is...I'm gonna be changing the fuel filter tonight...since it hasn't been changed since i got the truck and it's go almost 27000km on it...and i know that if I bring the truck into the dealer and get them to hear the motor...nothing will happen...siiigh
Old 04-14-2009, 06:07 PM   #9 (permalink)
Kansas Cummins Crew
Yeah, it definatly wouldn't hurt to change the filter. But if that doesn't work you should atleast try taking it to the dealer. Your signature says your stock, so they should help you.
Old 04-15-2009, 03:13 AM   #10 (permalink)
PNW86's Avatar
Fuel filter has been changed as of tonight...still knocking/ticking noise coming from motor under light acceleration in the low rpm range (maybe is normal?)...but i haven't heard of the louder knocking when rolling to a stop...hopefully the knocking won't come back...I'll drive the truck for a few days...if the knocking comes back I'll just take the truck to the dealer...then it will be dpf and egr delete...thanks for all you guys' help...I really appreciate it!
-Boris
Old 04-15-2009, 10:13 AM   #11 (permalink)
Kansas Cummins Crew
Huh? Keep us updated...
Old 04-15-2009, 10:46 AM   #12 (permalink)
My truck made some knocking sounds a while back. I went through the whole thing to figure it out. So I finnaly took off the Edge and was gong to take the truck to the dealer. After I took off the Edge the truck was fine. I sent in the Edge and the curcuit board had fried. Just a thought to someone else whoe whrote about the knocking sound as well, because I know that PNW86 is stock already.
Quadman is offline   Reply With Quote
