Water Separator Drain--How Often? - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 13 (permalink) Old 02-16-2009, 12:24 PM Thread Starter
How often is it required to drain the water separator part of these 6.7 trucks?
krazymatt is offline
post #2 of 13 (permalink) Old 02-16-2009, 12:26 PM
moeszyslak's Avatar
I usually just do it when I'm under there for an oil change. Doesn't take much time once your under. Sometimes only a few drops, sometimes a bit more.
'07 6.7L 4x4 Laramie megacab dually-lloonng bed Banks scoop, FOR SALE!! Ebay
moeszyslak is offline
post #3 of 13 (permalink) Old 02-16-2009, 12:44 PM
ynots57's Avatar
it would depend on how confident you are on the fuel you buy. i drain about 5,000 mi. intervals only because ive checked regularly and have never found any signs of water. i buy all my fuel at local truck stop.
i add an extension hose and drain into a clear clean bottle to visually inspect whats been drained. i only drain after trucks been sitting overnight so everything settles
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline
post #4 of 13 (permalink) Old 02-16-2009, 12:47 PM
I've owned a diesel for many years and have yet to find any significant amount of water in the filter/separator. Just in case, I drain mine at each oil change and change the filter out at each second oil change.
2007.5 6.7 auto 3500 SLT Quad Cab DRW - BADP Gen II - EGR MIA - Edge w/attitude = 2004 Suzuki XL-7 = 2001 Pathfinder SE 4x4 - 2011 Nissan XTerra 4x4
txrlk is offline
post #5 of 13 (permalink) Old 02-16-2009, 02:55 PM Thread Starter
I haven't looked at the part yet, but I'm assuming there is a valve there. Do I open the valve and just see what comes out or do I have to put the truck in the "on" position to get the fuel pump on? Thanks.
post #6 of 13 (permalink) Old 02-16-2009, 03:14 PM
Before you do anything, buy about 4' of 3/8" ID clear tubing. This is to replace OEM tube and cut to desired length to reach your container.
To drain, I go in over driver's side front tire and loosen the bottom of the filter a couple turns or so. Mine doesn't really drop anything out at this point, so I briefly turn the key to on (no start). This spits enough fuel out IMO to get rid of any water.
I got some watered down fuel one time at a station in Wyoming. Took several filter changes to get rid of the water in fuel light.
2008 3500 Big Horn SRW LB 4X4 Auto White P3 Trailer Brake Control
coolbreeze is offline
post #7 of 13 (permalink) Old 02-16-2009, 05:12 PM
The only truck I know of that ever had much water in there was my ma's '93 after the local body shop replaced the box and pinched/cut the fuel filler hose. The tire would throw water on it and got a fair amount of dirt and water in the tank over several months. The tractor tends to collect water too, but I doubt it will burn more than 20 gallons all winter. Unless you leave it outside and take two months to run a tank of fuel through, or get a bad tank, you shouldn't have to mess with it.
New: 2008 black MegaCab, 6.7, 4x4, auto, stnd gears, no performance mods, only 18k miles so far
Old: 1997 extended 5.9, 4x4, 5sp, 150k miles, mostly stock but added edelbrock shocks
bart9505 is offline
post #8 of 13 (permalink) Old 02-16-2009, 08:26 PM
I've found water (or some other sort of non diesel electrically conductive liquid) in my aftermarket separator, not much of it but something more than I would want going through the injection system.
I have yet to see any water separation efficiency numbers on the stock 6.7L filter so I really don't trust it for anything other than a secondary unit.
slagburn is offline
post #9 of 13 (permalink) Old 02-16-2009, 08:31 PM
1oldcj's Avatar
Slag - Are you running those Cat/Fleetguard filters in-line with the stock filter?
11.5 Silver HO CCSB 3500, 6.7, 68RFE, 4x4, Stock - 7878 miles
*Sold* - 07.5 Flame Red QCSB 2500, 6.7, 68RFE, 4x4, SMARTY, GDP - 29512 miles
1oldcj is offline
post #10 of 13 (permalink) Old 04-03-2009, 04:44 PM
Low Budget's Avatar
Is the water sep the same thing as the fuel filter?
2007 6.7, QCSB, 4x4,68RFE, 3:73, Insight, Amsoil bypass, 35x12.50x17 DC FCII on XD Misfit, 2" coil spacers Smarty 18ME, 5"TBE, Smoke Switch, B&G Modified Tune, Baffle gone
Low Budget is offline
post #11 of 13 (permalink) Old 04-03-2009, 05:21 PM
i just open the valve on mine with the truck running, and it will poor some diesel out and then i close it back after about 3 seconds, i know i am loosing some fuel, but it really isnt that much, and this way i know i am flushing it out.
2014 Ram 2500 Laramie Limited Mega-Cab 4x4 Auto. Granite Crystall Metalic
MattTN23 is offline
post #12 of 13 (permalink) Old 04-03-2009, 05:48 PM
The Radio Flyer
gsbrockman's Avatar
iTrader Score: 28 reviews
I generally allow the Blue Bus to mark its territory about every 2nd fillup.
Greg
2014 RAM 3500 Tradesman Crew Cab 4x4 DRW 6.7L Cummins Turbo Diesel 385 hp 850 torque and AISIN 6 speed automatic in Flame Red, Snow Plow Prep Group (Protection Group & 220A Alternator), Popular Equipment Group, Chrome Tubular Side Steps, Chrome Appearance Group, Single Disc CD, LT245/75R17 Firestone Transforce H/T tires, Trailer Brake Control, 3.73 axle ratio, 5.0 Radio w/SIRIUS, ParkSense Park Assist, Parkview Rear Backup Camera, B&W GNKR 1314 Gooseneck Hitch. Purchased new February 20th, 2014. Currently : 205,114 miles and 3,793 hours as of January 13th, 2017. (Average Miles Per Hour = 54.1)
gsbrockman is offline
